How do you store your grease gun
   / How do you store your grease gun #11
Mine are laid flat on a middle shelf in the workshop. I wrap the nozzles in a rag, the same one that I use to wipe it with prior to putting them away.
   / How do you store your grease gun #12
Nail on wall, only get about ten days a year that are hot enough to make it drip, my waste oil can (old drum type five gallon gas can) is on the floor below it, so any drips are unnoticed on the top.
   / How do you store your grease gun #13
Thrown in a milk crate in the back of my pickup along with about 8 million miscellaneous items. It is a work truck after all...a little grease is good for the paint!
   / How do you store your grease gun #14
Mine hang on nails on the wall in my work shed. Any drips, which there probably are some in the hotter part of the summer, hit the old sawn board floor and are soaked up.
   / How do you store your grease gun #15
If they leak on a hot day, am I using the wrong grease?
   / How do you store your grease gun #17
I take a tall skinny throwaway propane tank (empty of course) and cut the top off it. Drill 2 holes vertically along the axis near the top to mount it to the wall or work bench and 2 holes diametrically opposite the first 2 so you can reach through with a screwdriver. Fold a paper towel or small piece of a rag into a little square and drop it in the bottom to soak up any drips. Something I learned from my dad...he used to use a soup can and I took the idea to the next level.
   / How do you store your grease gun #18
I built one like this - works great
   / How do you store your grease gun #19
A good quality grease will not leak oil.
Maybe not... I don't honestly know, as I do not consider myself to be a lubrication specialist.
.....but, the grease recommended by my dealer, who covers my warranty work, will drip from the grease gun if left hanging in the shed in the summertime..
   / How do you store your grease gun #20
I never thought of hanging a grease gun. I just toss mine on the shelf under the work bench.
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
71062 (A49346)
71062 (A49346)
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
