Brought home another L series on Friday!
/ Brought home another L series on Friday! #21
Is the 3430 a Grand L? I've been googling but havent been able to find out.
As far as I know, all Lxx30, Lxx40 and now Lxx60 tractors are considered Grand L's. The Lxx00 and Lxx01 are standard series. The grand L's have features like arm rests and the intellipanel dash that are missing on the standard series. More info on the difference is available here:
Ain’t Life Grand: The Difference between the Kubota Standard L Series and Kubota Grand L Series — Humphreys' Outdoor Power
Some features depend on the model year however.
Great link. Thanks.
My first thing to get done is adding 3 rear remotes. I understand kubota has a kit for the 3430HSTC. Will have to price it out.
Want to be able to get a top n tilt installed along with being able to run a grapple in the future
/ Brought home another L series on Friday! #23
Soldier415: Nice tractor,What size Land Planer is that ,I am debating on purchasing a 60" or 72"
Its the 60". If you are going to use it for driveway maintenance, good idea to go with half your road width. That way you can run with the working width covering half the road with the inner wheel/skid on the top of the crown.
My road is 10' wide. If I went with the 72" it would cut off the crown in the center of the road.
/ Brought home another L series on Friday! #25
Great link. Thanks.
You might want to check with MtnViewRanch who owns Fit Rite for a TnT setup and advice, I seem to remember Kubota running way behind on these components.
Fit Rite Hydraulics - fitritehydraulics.com
/ Brought home another L series on Friday! #27
Great link. Thanks.
I added remotes to L5030 (no cab) , was pretty easy.
I'm not what you would call mechanically inclined... :)
Luckily my father in law is a mechanic and has his own shop where we can do the work. Just need to get the right part numbers from Kubota
/ Brought home another L series on Friday! #29
I have a QA for a LA723 loader I need to get rid of. I bought my L3130 without QA, then bought qa pallet forks. Never modified my bucket for qa, I traded it pin on as I bought it.
Buckeyefarmer, I sent you a private message.
Now just need to get the feel of the HST transmission and correct throttle settings. Don't want to burn fuel unnecessarily when just driving without a load.
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2025 IRANCH 15in. Log Grapple Mini Excavator Attachment (A59228)
2025 IRANCH 15in...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
2019 PETERBILT PB520 GARBAGE/SANITATION TRUCK (A59823)
2019 PETERBILT...
2001 International 4000 DT 466E (A60462)
2001 International...
