   / Harbor Freight Tools that don't suck #7,271
One of the HF reviews suggests that the nitride coated ones are quite a bit better with anything harder than mild steel. I do need them to work in "hardened" steel. Any thoughts?
I need both SAE and metric. Wish there was a nitride combined set so I didn't have to pay for two sets of handles etc.
   / Harbor Freight Tools that don't suck #7,272
I've carried a lot of stone and gravel and find it essential. Maybe 10 dually loads, up to 3,000 lbs but usually right around the 2,000 it's rated for.
I've "brackets" for my Reese 5th wheel/goose neck hitch so I lay in a few 2x4's then put down a sheet of plywood to "level" my bed, then a tarp (HF), then the mat, then the unloader, then have them drop a ton or so on top. The tarp is big enough to go up the sides and I can pull it over so stones and dust do not fly out. And if the "or so" becomes a lot I generally get my son to shovel some off the top first. I don't want to rip the unloader.
After the load is "cranked out" it's fairly simple to "disassemble" and pull the tarp and what is left out.
I've also used it when Lowes mis-priced some 12x12 concrete flagstones and I picked up two bed loads. I used it to crank the pallets they had pushed to the front of the bed back to the tailgate.
Yep same experiences... I hadn't used it for a while and forgot the tarp and the mat last weekend for a load of compost. The tarp saves lots on clean up and the mat saves my back and the chance I will rip the fabric. Like minds, newberry!
   / Harbor Freight Tools that don't suck #7,273
That 60 pc set with both metric and standard would be worthy for most people tool chests. I have a two Craftsman sets one metric one standard but if I didn't have any tap and dies I would probably get myself one of those. At the motorcycle shop I frequent there is one of the 45 pc sets nice investment and I always though about getting one but most people won't often need those larger sizes. I'm thinking only a few times over the years did I ever need something larger than even 1/2".
Years ago I had a set very similar to that 21 pc in the links but in Metric and I think I came from JC Whitney at the time and I actually did rethread an entire brake rod using one of the dies for on an old motorcycle I was restoring but overall wasn't much of anything to talk about and the taps were very poor quality.
Like someone pointed out using taps and fixed dies to just chase threads or clean out holes isn't what you really want (though with a split die you can adjust some) you do run some risk of over cutting or actually recutting threads.
So I do realize this IS the Harbor Freight thread :D but I don't think HF sells a thread chaser/restorer kit.
I would recommend them. I also have one, again a Craftsman and the same set is sold under several other brand names and of coarse there are plenty others just look on Amazon.
I use that much more often for cleaning up nuts and bolts. Plus they have the thread files too
   / Harbor Freight Tools that don't suck #7,274
Hopefully, you're using jack stands to hold up the mower after you lift it with that electric hoist. There's no way I'd work under a mower with only that hoist holding it up.
Of course
   / Harbor Freight Tools that don't suck #7,276
And an even better back saver is a 35 year old son!!
   / Harbor Freight Tools that don't suck #7,278
Every time I go in the store I wonder if the workers will get cancer from the smell. As for the larger step drills, I burned the big one up trying to make a hole in my stainless kitchen sink to add a soap dispenser. It was fine until I got into the step that went from 7/8" to an inch. I needed to get to an inch. I used a cutoff wheel to sharpen it up and did eventually get through the thin gauge metal but that bit seems soft on the big numbers. For years I beat up the smaller 3 drill set I have from HF and it still cuts well. This was the first use on the larger of the 2 bit set.
I think keeping reducing the drill speed as the hole size increases is key to bit life but not all drills permit one to do that.
   / Harbor Freight Tools that don't suck #7,280
Welding table on sale.
Bruce
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
