Kubota B21 Fuel Stop Solenoid Issue
/ Kubota B21 Fuel Stop Solenoid Issue #1
RobbieBones
New York
I had an issue starting the machine, realizing I had this issue in the past I knew to look at the stop solenoid. Played around with it and for some reason the tractor started again. Ran it half a day then while using it with the front bucket up it just died! I could not get it to start.
I have had this issue in the past and replaced the stop solenoid to solve my problem. I believe that was the last time I was on this site. Anyway the problem is back. Its a two wire solenoid when I pull it off the engine I can start the tractor no problem, runs fine. When I test the solenoid with a jump from positive terminal and grounding it, it sounds like a machine gun going in and out repeatedly never locking in or out. Ohms test shows 0 all around. So I believe its bad. My other problem is I do not have voltage to the two wire lead at all no matter what the position of the key is. I had voltage once while messing around with the solenoid but now no matter what I do I can't get voltage to the plug, (even cut the wires to check if it was the plug) no voltage. Fuses are all good and cleaned.
So I also pulled the ignition switch, it has 4 wires, using the red wire on the plug and a jumper wire I get power to dash, then glow plug but I can't jump start the engine. Not sure if I'm suppose to be able to ??? I Put the key in and turn it, engine starts. I was doing this trying to get voltage to the fuel stop solenoid with no luck.
So what provides the voltage to the fuel stop solenoid??? I think in the run position there should be voltage to the solenoid. At what point in the turn of the key should I've heard the click of the solenoid or get voltage to the plug? Is there a way to check the ignition switch properly? Is There something else to check? Thanks in advance for the help.
/ Kubota B21 Fuel Stop Solenoid Issue #2
A keystop solenoid only has power for 5-10 seconds after key is turned off or one of the safety switches is tripped. No power in run position and power is usually supplied to the solenoid by the keystop timer relay. Solenoid should pull in solid and vibrate.
David
I'm not getting voltage at all to the solenoid. Does that mean a relay is bad or the ignition? I believe when it worked I would turn the key and hear a distinct click, continue turning key the tractor would start. I guess the click was the solenoid retracting, pulling out of pump, enabling fuel to injectors? It is then held out with voltage? Or is it suppose to stay locked in/retracted when off or tractor is running with no power to solenoid?David[/QUOTE]
QUOTE=David_Kb7uns;4746133]A keystop solenoid only has power for 5-10 seconds after key is turned off or one of the safety switches is tripped. No power in run position and power is usually supplied to the solenoid by the keystop timer relay. Solenoid should pull in solid and vibrate.
/ Kubota B21 Fuel Stop Solenoid Issue #4
Kubota has used 2 types of fuel control solenoids, you will have 1 OR the other:
1. Fuel shut off (Has 2 wires) and uses a shut off timer to supply power for about 10 seconds After key is turned off.
2. Fuel Turn on and hold on Solenoid (has 3 wires) Gets "pull On power" during engine crank, Gets "hold On power" when key is in run position.
You say you have 2 wires so it should be the 1st type... all it ever does is kill fuel flow... (gets 12 volts for about 10 seconds) from a timer relay, AFTER key is turned OFF.
One of your wires is Ground the other is the timed 12 volts...
/ Kubota B21 Fuel Stop Solenoid Issue #5
My B21 FUEL STOP solenoid has a 3 wire solenoid, from my info should get power on white when key on, and red when cranking, ground is black. White to black is ~15 ohms, red to black 0.4 ohms. If you have a late model with OPC (operator presence control) from my diagram you could have a 2 wire solenoid with metal case to ground, and from the wiring it shows both wires are energised together, probably only for shutdown, but there are many faults in kubota diagrams so I couldn't be sure.
/ Kubota B21 Fuel Stop Solenoid Issue #6
Is this an original solenoid? Part number from tag? Try powering both wires at the same time, while grounding the case and see what happens. It's possible that it has a switched pull in coil to protect it.
Thanks for the responses. It's a 2007 B21 with OPC (which is Bypassed at this time). It has two red wires to the solenoid red,red/black never tried power to both but i believe it grounds by the unit being bolted to engine at least thats the only time it reacts when I put power from battery to it. Where and what does the timer look like? Anyway of checking the ignition?
When I put test voltage from battery to both posts on solenoid it retracts and stays retracted. Disconnect one post and rod goes out. So I'm not getting voltage in the 2 red wires.
KennyV are you sure (2wire) does not stay energized while the tractor is running???
/ Kubota B21 Fuel Stop Solenoid Issue #9
Near as I can tell from looking at B21 pictures on the internet you have the dual circuit (coil) solenoid (it bolts to end of injection pump) and it is using the tractor ground instead of a third wire.
David
David thats what I have. When I put voltage to both prongs on solenoid and have the unit touching the engine the unit retracts and stays there take power away and the rod comes out. What I'm trying to figure out is why I can't get power to the two wires that go to the solenoid. I'm thinking its the starter relay which is under the dash. Nothing I touch or clean gets power to the solenoid. The last time the machine was running with solenoid in the machine just stopped running on its own. I have the seat safety switch bypassed and was standing alongside the tractor. It just stopped running.
I did find two wires coming from the square black box under dash were chewed by mice. I wrapped them each in electrical tape. Maybe they shorted something out. But I did that before the tractor started normally and then just died.
Ok found the relay starter. Denso 056700-6690 or new part number 35800-75070. The plug has 2 reds a black a white/blue.Testing the plug to relay I get 12v with ignition off to a black and one red nothing else. Ignition on same thing only 12v to one red. Shouldn't both reds go hot?
/ Kubota B21 Fuel Stop Solenoid Issue #12
Ok, let's clarify a couple of things as what you say leads me to think someone has done a big wiring change, which makes it difficult to diagnose, or you are unsure as to what has been done to the wiring.
First you say
So the OPC controller is no longer in circuit and the wiring around this controller has been manually bypassed. Therefore, the control for the starter motor no longer comes from the OPC, but would need to come from the key switch or a relay controlled directly from the key switch and the control for the fuel stop solenoid relay no longer comes from the controller, and would need to also come directly from the key switch?
Later you say
If you have the OPC bypassed, the seat switch plays no part in the circuit.
Do you have the OPC bypassed, or do you just have the seat switch bypassed?
The wiring of the KEY STOP SOLENOID RELAY in a B21 with OPC has 2 x heavier Red/Blacks, 1 x medium Black, and 1 x small White/Blue wires going to it. There is no starter relay in the B21 with OPC, the starter is controlled by the OPC.
The Blue/white is the control circuit coming from the OPC.
You mean from the BYPASSED OPC? So are these wires chewed through, or is it just the insulation that is chewed. I expect you may need to go back and have a decent look at those wires. What color are the wires?
Getting back to the FUEL STOP SOLENOID - as I mentioned previously, it "appears" your solenoid may have a SWITCHED pull in coil for protection of the pull in coil.
To test and PROVE the operation of your solenoid correctly, you need to power the "hold in" coil, then also power the "pull in" coil, then remove power from the "pull in" coil.
The hold in coil won't pull the solenoid in, but will draw a little power and may move the plunger a smidgen. This is like when the key is in the ON position. When you then also power the "pull in" coil, the coil will pull in and stay in, even when you disconnect power from the pull in coil. So normally for this style of coil, you turn IGN on, hold in coil is energized, then turn to START, and pull in coil is energized which pulls the solenoid in, you release the START key back to IGN, the hold in coil continues to HOLD the solenoid in.
The above is testing for a normal style 2 circuit solenoid coil. From the wiring diagram I have it shows both circuits being energized together, that's why I believe it has a switched pull in coil, and you're testing saying it goes off like a machine gun confirms that style, because when the coil pulls in, it disconnects/switches the pull in coil off so it doesn't burn out, and then if the hold in coil is not energized, it will pop back out and re-energize and come back in. Test the solenoid as above and see what you get.
I expect the OPC is actually still in circuit and is probably functioning correctly, I expect your solenoid is OK, and you have some chewed wiring to deal with, and if it's chewed in one place, it may be chewed elsewhere. The chewed wiring is probably affecting inputs or outputs to or from the OPC and the correct operation of the OPC. However, the OPC could be faulty, or you are missing other critical inputs such as PTO and HST inputs etc.
100td Thank you for your help. Wish I was more of a mechanic or electrician so I could explain things better.
First the OPC, I thought that meant just the safety switch for the seat. My mistake, the safety switch I bypassed was at the seat switch with a jumper wire. All other safety switches are working. Meaning clutch needs to be down, forward and reverse needs to be centered etc to start the machine.
I understand know that the black 2x3 box under the dash is the OPC unit. (Coleman parts calls it a Controller) That is still hooked up and I found two wires with the installation chewed off which I repaired. The tractor started a few time as it normally should after that repair. Then while I was off the tractor with it running it just died. A day earlier before this repair the tractor gave me a hard time starting, I realized it was the solenoid because I wasn't getting any smoke out the exhaust while turning the key. I didn't hear the usual click either. Then for no reason I turned the key heard the click and the machine started. Ran it half a day. Shut it off and again it happened. That is when I removed the solenoid, the dash, and found the wires. Wrapped the wires, tested the solenoid with a jump from the battery and it sounded like a machine gun.
After read some responses I tested the solenoid with two hot wires and grounding it to the engine and the solenoid locked in and stayed in.
The wiring for the key stop solenoid relay is excactly like you describe. (Coleman Parts calls it a starter relay) I used the wrong terms to describe the part. There is an OPC it is connected.
In the morning I'll double check all the other inputs and test the fuel stop solenoid.
If the wires on the OPC all check out and the other inputs are good. Then it is the key stop solenoid relay that is bad? Why is only one red/black to black hot? What makes the other red/black hot from the key stop solenoid relay? When I removed the key stop solenoid relay) the small black unit bolted to a brass colored bracket near the OPC) there is a rattling noise, is this normal?
100td anyway you can post the wiring schematics? Thanks for your time.
/ Kubota B21 Fuel Stop Solenoid Issue #15
Can't post diagram at the moment, my HDD crashed/wouldn't boot yesterday and I am in process of try to save everything I can, scanner is off network at the moment (I shouldn't be wasting my time on here!) Will try tomorrow, see how I go. When the relay is energized the other red/black will become hot when the relay closes and switches it to the existing hot red black.
For the fuel relay to turn on, the blue/white needs to be energized by the OPC.
The OPC needs HST, PTO and seat switch, and start signal from key switch.
The clutch pedal switch is directly in circuit with the starter motor solenoid which is controlled from the OPC.
As mentioned previously, your OPC could be bad, but you need to ensure everything else is correct. Not sure about the rattle, but for it to work it needs power on blue/white as noted above. When it gets that, the 2 x red/blacks are joined at the relay powering the wire going to the solenoid. At some point both solenoid wires are joined together in the harness or at a connector (per the diagram). This is why I said the solenoid must have a switched pull in coil, otherwise it would burn out.
I don't know the exact logic of the OPC controller but I'd hazard a guess that it won't cut the fuel for say 500msecs when the seat is in the forward position due to you bouncing on the seat on a bumpy road.
Update.
Fuel stop solenoid tested good. I was able get it to hold in with only power to one wire.
The wires that were chewed on the OPC were Blk/WH, BRN/RD, WhT/BLK.
I was able to get power to the key stop solenoid wh/blue. But only after monkeying around with the OPC unit.
It appears the OPC unit has a fault in it. After putting the fuel stop solenoid back on and everything in place I was able to get the tractor to start. However moving and or squeezing the OPC unit the tractor would shut down.
I think bad OPC!
100td thank you for all your time. Hope you get your PC up and running.
/ Kubota B21 Fuel Stop Solenoid Issue #18
A little off topic, but this fuel cut off issue has been discussed several times over the past months.
I have looked on line using the google search, but have not seen a "generic" fuel controller offered.
I have a Mitsubishi engined tractor with a Mitsubishi fuel control module that has symptoms much like the OP. (two wire solenoid, random cut out, and random no start.)
I've just disconnected the solenoid and use the manual fuel cut off lever to stop the engine I really should repair the control by the key switch.
CalG,
It was more of a safety issue with my machine. To turn it off without a fuel stop solenoid I had to use my finger or screwdriver. In the end it ended up being even more of a safety/headache issue because it turned out to being my OPC unit that controls even more then just the fuel stop solenoid. My machine would just die on me. Looks like $114 fix for me.
/ Kubota B21 Fuel Stop Solenoid Issue #20
Couple of extra pages on the OPC as well, I hadn't looked at them, only the main diagram. Ha, upside down and all, you'll have to flip them. Check you wiring and connections thoroughly and see if you can get it all working back to original spec. Pull the OPC and check the pins/connectors, and perhaps if it's easy, check solder/wire connection on the PCB if there is one. Not sure will attach here very well, will give it a go, if it doesn't work, message me your email.
  • B21 OPC.pdf
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
2014 DORSEY 53X102 EXTENDABLE TO 90 FT (A59905)
2014 DORSEY 53X102...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2007 Sterling 360 COE 40/45 Box Truck (A59230)
2007 Sterling 360...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
