What did you do at work today?
   / What did you do at work today? #11
Thought of doing some work last week. Haven't got to it yet...
Welded some grips on the fingers for a robot on some AR400 plate that was water-jet.
   / What did you do at work today? #13
Removed the Injector Pump and starter from my 3910. Pump will be rebuilt, leaking diesel. Starter solenoid requires 3 or 4 hits before engaging.
Who has time for retirement.....
Not sure where you live in MO but a guy on Jackson MO fixed a leak in the top of my pump for $75 without having to rebuild it.
   / What did you do at work today? #14
We've got a good small shop locally. Where mine is leaking he has to disassemble the pump to fix it. So he'll put a kit in it replacing all the seals and gaskets. Even then, it'll probably be $200 or so. Said it depended on what he found. Hoping for good news. Thanks for the tip though!!!!
   / What did you do at work today? #15
Used the CMM this morning to help a supervisor get a couple of parts up and running for a big customer. Ours has been an abrasive relationship since I started here. However, getting him the info he needed for adjustments in about 2 minutes seems to have softened him a bit. He even thanked me (that's a first).
CEO brought around paychecks already today, too. I'll call this a good day.
   / What did you do at work today? #16
Keeping low profile..to much b.....ing going on. :rolleyes:
   / What did you do at work today? #17
That was my gig for 30 years. DEA, Sheffield, Mitoyo, but mostly Zeiss.
Maybe stick with welding? :)
You say that cause I threw the piece out of the mill yesterday? lol. I love running the milling machine, I been welding for 31ish years and I get burnt out on it pretty quick.
The Woods bush hog I bought has a baler belt on the front of it as a guard, it's torn up. I was looking thru the manual and found a picture of a chain option. I started working on that. We don't have any fab machines to break or bend so I am going to make it angled with a plate and piece of angle iron. I started cutting slots and got one done. The guy at the hardware store is going to flip out when I tell him I need him to cut me 56 pieces of 5/16" chain 7 links long, lol.
2006 CHEVROLET EXPRESS SERVICE VAN (A56138)
2006 CHEVROLET...
UNUSED 4'6" METAL DEER FAMILY SHOOTING TARGET (A52706)
UNUSED 4'6" METAL...
KOMATSU D51PXI-24 CRAWLER DOZER (A52707)
KOMATSU D51PXI-24...
Chop Saw and Max 43 Plasma Cutter (A54865)
Chop Saw and Max...
ALTEC CP12LF HYD (A52707)
ALTEC CP12LF HYD...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
