Snow Equipment Owning/Operating Block heater to warm diesel
   / Block heater to warm diesel #1
Fosters69
Member
Hillsborough, NH
Mahindra 26xl
Hi all,
It is supposed to be frigid the next couple days and they are threatening 3-6 inches of snow so I may need the tractor and blower to start. I'm going to pack an old pillow around the fuel filter and I have a tarp over it to hopefully prevent the wind chill, but can I/should I leave the block heater plugged in and on for 2-3 days Straight? Will it hurt anything or even help to keep the fuel from Gelling?
Once again thank you all,
Dan
   / Block heater to warm diesel #2
I sometimes leave my truck (Duramax diesel) plugged in for days, no problems yet.
   / Block heater to warm diesel #3
Leaving the heater plugged in won't hurt anything. If you keep the engine compartment closed off it would help keep fuel from gelling.
   / Block heater to warm diesel #4
If your diesel is summer diesel, or even winter diesel, you should add some fuel additive like black label Power Service. This should keep it from jelling. Should be mixed with the diesel good before pouring into your tank. You can plug the heater in 24/7, but most folks just plug it in for a couple hours before you are going to start it. Best if you can park it inside somewhere. I keep my tractors in a barn that seldom gets below freezing inside since I heat up the center all day with a wood heater. The cement floor holds the heat pretty good thru the night. Another important thing to do is keep the tank full of good, clean diesel. Water in fuel anytime is a pain, but even worse in the winter.
   / Block heater to warm diesel #5
I used to plug in the block heaters on my gas fired vehicles every night when I parked them and usually remembered to unplug them the next morning. Lots of folks would forget to unplug prior to driving off and you would see them dragging the cord around in town. Never had a problem with leaving them plugged in other than burning the extra electricity.
   / Block heater to warm diesel #6
Hey Gary,
How did you know I did that??????????????
If he has a salamander he can also tarp the mule and heat it up that way too but keeping the block heater plugged in around the clock will not hurt anything other than making the electric meter run a little faster.
   / Block heater to warm diesel #7
I know of several ranchers that feed at remote lots that are plugged in 24/7. Less than $2 a day for a 1000 watt heater.
   / Block heater to warm diesel #8
Leaving the block heater plugged in won't hurt anything but if your fuel filter is in the back of the tractor away from the engine the heater won't be able to help keep fuel from gelling. Proper grade fuel and or treatment of fuel will help prevent gelling.
   / Block heater to warm diesel #9
Hi all,
Dan
The pillow around the fuel filter will do no good unless you have a heat source warming the filter.
A tarp will do no good for wind chill. It's a machine, it doesn't feel wind chill. Only us stupid humans use that term.
Plugging in for multiple days might have a positive impact on gelling if the engine warmth can be transferred to the fuel tank. You should always treat your fuel in temps below 20F degrees.
If your block heater is a good one, thermostatically controlled, so it doesn't cook itself, it will be fine. Most block heater systems reach their maximum effectiveness after a couple hours, then are just maintaining that temp. Maybe plug it in a couple hours before you need it.
I'll add one caveat for using a tarp or some type of cover. If you are providing a heat source, such as your block heater, it's effective. If you are not providing a heat source, it's non-effective.
   / Block heater to warm diesel #10
I always cringe about wind chill on a machine. If so how about driving 50 or 70 MPH on a 0 degree day!
White Metal Roof Panels (A55758)
White Metal Roof...
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
2020 DRAGON ESP...
2015 Peterbilt 567 Wet Kit T/A Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
20' FLAT WAGON W/ METAL BED (A58374)
20' FLAT WAGON W/...
