Frost Hook
/ Frost Hook #1
Thirsty
PA
Kubota BX 2230, L5460 FWD, HSTC
I'm looking for a frost hook for my Kubota BH 92 Back Hoe. I can't seem to find one on line. Any ideas?
Thanks.
/ Frost Hook #2
What is the difference between a frost hook and a ripper tooth?
http://www.tractorbynet.com/forums/attachments/211702-mie-ripper-my-bh92-3.html
http://www.tractorbynet.com/forums/...per-bucket-teeth-post2723268.html#post2723268
/ Frost Hook #3
Has anyone used something like this to rip red shale? Most of my acreage sits on a 60' thick shale ledge covered by 1 or 2 feet of topsoil. I'm constantly hacking away at the stuff to do even minor excavations. I replaced the 18" bucket (4 tooth) with a 12" (3 tooth) on my BH92 and it helped somewhat. It seems to me a single tooth would be even better. I would love to get one if it would be effective. I'm not looking to dig a foundation or anything that large. I had to hire a D8 Cat to do that. I just need to be able to do some trenching and landscaping tasks.
Thanks in advance for any suggestions.
/ Frost Hook
I am really looking for a root ripper that will fit my backhoe. All of the one i find on-line are to big. I waas told to look for a frost hook. That is the reason for the title of my post. If no one makes them, any one know where I can get plans to build my own?
/ Frost Hook #5
I picked up a railroad cribbing bucket a few years ago for my Case 530 backhoe. It has 2 teeth and is only about 8" wide so it works better for digging out tree roots than my standard digging bucket (about 20" wide). I found mine on craigslist for about $250- perhaps you could find something similar and modify it to fit your machine.
/ Frost Hook
Not a bad idea, I'll have to watch craigs list to see what comes up.
Thank you.
/ Frost Hook #7
Off the wall: a steel spring slipped edgewise into two brackets on the inside of the bucket. Held in with one pin and angle grinder sharpened on the leading edge.
Easy to install or remove?.
/ Frost Hook #8
Until this thread, I had never heard of the term "Frost Hook". Maybe it is a regional thing?
/ Frost Hook
Some call it a root ripper.
/ Frost Hook
Another interesting idea. I'll have to think about this to see what I can come up with.
/ Frost Hook #14
Many of the folks who supply a ripper tooth or frost hook will make one to fit your hoe. Give them a call. I got a BroTek (made in Canada) for mine but to tell you the truth I don't think it's the best for ripping roots as the folks with a Piranha tooth seem to have more success with roots. The Piranha has teeth while the BroTek does not and mine is as dull as a froe. What sharpening it has looks like it was done with a torch.
/ Frost Hook #16
They are sometimes called Frost Picks in our neck of the woods.
MIE's looks like a nice product for the money
/ Frost Hook
Looks like Bro-Tek may have what I'm look for. I've sent them a message. Thanks to all for your help and comments.
/ Frost Hook #18
Let us know what they say. I haven't had the need for one but I think I might, and I've been waiting for Bro-tek to list one for the BH-92. They have one listed for all of Kubota's other backhoes but not that one. Surely it can't be much different than the BH-90.
/ Frost Hook #19
They will make one to fit your hoe. All you have to do is supply a few measurements from your bucket detailing the dimensions of the mounting pin holes then they make it up and ship it to you via parcel post. It didn't take long at all and wasn't expensive. About a week I think and I'm on the opposite coast.
Like I said, it could be better for ripping roots if it had teeth like some of the others have.
/ Frost Hook #20
FWIW, the buckets from my old BH90 fit my BH92 with no problem. The dealer told me all buckets are interchangeable between the 90 and 92 models. I assume the same would be true for a ripper.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
John Deere 6140R Tractor (A64047)
John Deere 6140R...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59910)
2021 UTILITY VS2DX...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2005 PETERBILT 379 CAB ONLY (A63569)
2005 PETERBILT 379...
2020 MACK GRANITE (A63569)
2020 MACK GRANITE...
