Rats ate my wiring. Need help.
   / Rats ate my wiring. Need help. #1
davezerg
rio grande city, texas
None
Ok so I kinda left my tractor in the ranch outside in the elements for a couple months. When I finally wanted to move it I noticed it wouldn't start. Thought it might be the battery. I opened up the hood and saw that the small ground wire was cut and some other damage. The wires to the headlights are completely cut as well. I was hoping you guys might have some info on how to fix this. I'd post pics but I'm not sure how to. Tractor is a 2013 John Deere 5045e. Maybe you guys have some pics of original so I have an idea how it was before. Thanks.
   / Rats ate my wiring. Need help. #2
When you say fix this, do you mean reconnecting the cut-chewed wires or preventing mice or rats from doing this again? It happened to me once - mice chewed through a couple of wires - and they had started to build a nest on top of the gas tank.
There was a thread here - many years ago - about ways to keep the critters away. Things like fox urine, moth balls, cats. .. I don't recall all of the suggestions. I simply respliced the wires and luckily it did not happen again.
I need help on how to fix it. I'll keep it out of the elements from now on and put some mice deterrents on it. Maybe one of those fake owls on top as well. Any info on how to rewire or like I said maybe a pic of the battery cables.
   / Rats ate my wiring. Need help. #4
an onion bag of mothballs will keep the mice away.
As for the cut wires, clean the ends, get some no-ox and butt connectors and just match wire insulation color/stripes / markings. But connectors aren't awesone.. but if you cleant he wire and seal with some no ox grease, etc..
   / Rats ate my wiring. Need help. #5
I prefer to use the waterproof, heat shrink butt connectors for stuff that will spend any significant amount of time in the elements - Amazon.com: SOLOOP 1Pcs Heat Shrink Butt Connectors Crimp Electrical Terminals Heat shrink waterproof wire connector Red: Car Electronics.
Count yourself lucky, we just got my wife's car back from having rat damage repaired. Total was right at $6,000 in damage. They had to pull the entire interior out of the car to inspect the harness, replace one of the control modules, several sensors and quite a bit of wiring repair. Thankfully, insurance covered all but about $1,000 of it.
   / Rats ate my wiring. Need help. #6
Now is a good excuse to buy the tech manual for your tractor. It will have the wiring diagrams in it.
   / Rats ate my wiring. Need help. #7
Be sure to check the air filter too. That's a common area for them to build a nest, or chew through the filter. That's not something you want to suck into your engine.
   / Rats ate my wiring. Need help. #8
I had a fairly new Chevy pickup that mice got into the wiring just below the fuse box in the engine compartment, and chewed the insulation of dozens of wires... a royal mess. I wound up separating the wires and spraying insulation vinyl onto the bundle of wires... seemed to keep the wires from shorting, and stopped corrosion, but it wasn't pretty. Replacing the harness might have been an option, but jeez!
   / Rats ate my wiring. Need help. #9
FYI, They make a crimper for the insulated butt splices, if you use the crimper for the non_insulated on the insulated you damage them and might has well have saved your money. The above butt splices perfectly acceptable repair. I have been known to cut the cost effective plugs out(for say lights) and use above butt splices instead.
   / Rats ate my wiring. Need help. #10
No rats here but Lord do we have the field mice. Best answer is moth balls in a cloth sack and a pack of hungry barn cats. I've heard the mice don't like peppermint extract/oil either - haven't tried that yet.
1992 - the mice completely destroyed the wiring in a BRAND NEW Chrysler - $895 bill to fix.
International Farmall 856 2wd Tractor (A52128)
International...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Allis Chalmers Disk (A50515)
Allis Chalmers...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
