Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%?
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #1
KYErik
South central IL
1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I am looking for a spare bulb for an old Bell and Howell 8mm movie projector. It takes an 80 watt bulb that runs on 30 volts (supplied by the projector). The correct bulb is about $55.
I found a 250 watt, 120 volt film projector bulb at a yard sale for $1 and bought it. Will this bulb use 62.5 watts if I run it on 30 volts instead of 120 volts? Will it last as long?
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #2
The bulb will last forever,,, but, it will give off a little glow, if any light.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #3
You might have to strike a match to see the glow.. Well, it might not be quite that dim, but it will be very very dim. And it will last a very very very long time. :)
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #4
Watts/Volts/Amps/Ohms conversion calculator
My guess is this....
The original 30v 80w bulb would be about 11.25 ohms resistance and pull about 2.6666 amps.
If you have a 250w bulb rated for 120v it should have about 57.6 ohms of resistance.
So, if you put that 57.6 ohm bulb in a 30v circuit, it'll draw about 0.521 amps and only put out about 15.625 watts.
It'll be very dim. That's my guess.
Go to that link and plug in some numbers. Its kind of fun.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #5
E=I^2R
It's the exponent ^2 that tells you the entire story.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #6
But, it is hard to calculate the resistance of a light bulb because it is dynamic. In other words as the light bulb heats up its resistance changes considerably as more current flows thru the filament until equilibrium is reached. So your working voltage, current and resistance's are likely correct for a stabilized bulb. BUT your low voltage will not swing the resistance as much. So it is kinda hard to figure. Perhaps someone with more practical real world light bulb experience could weigh in on this OR get this, we could do actual experiments of measuring lumens output, at the two voltages and current measurements, OR we could just screw the thing in the socket and see what happens... Yeah.!
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #7
Quick! To the lab!!! :)
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #8
For a dollar, I would just screw it in. It's not going to burn up unless it is defective from the git go.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #9
I have some lightbulbs in my kitchen in a 4 bulb fixture. We've been in the house about 21 years. Those lights are the first on and last off every day. One finally burned out a few years ago. I had a hard time reading it, but I finally figured out they are 130v bulbs. They give off a nice yellow color, not harsh white. Since there's 4 of them, its plenty to light up our little two-butt kitchen.
   / Light bulb question- running a 120 volt bulb at 30 volts- watts reduced by 75%? #10
When you heat up steel to make it white hot and glow do you think that heating it half the temperature would make it glow half as much?
That's doubtful and the filament inside the bulb only gives off light at a certain temperature and is not linear lumens:wattage input.
Still a fun experiment. Keep us posted.
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
Cushman Cart (A55853)
2015 Peterbilt 320 Trash Truck (A55973)
2015 Peterbilt 320...
2006 APPA TL (A55787)
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
