1.3 cordsHow much wood do you think you have in there?
All winches are rated on the first wrap.
One thing to note is that when some winch manufacturers (they might all be this way now) list the pull rating, that number is for the line pull at the first wrap on the drum.
The reason I mention this is because if you only need say 80' of cable (just an example) but you've got 200', the extra cable is only hindering your pulling capacity.
Of course, you can always make it shorter, but there's no way to put 230' of cable on a machine that is only supposed to have 165'.![]()
That's what I would have thought too. Sawyer Rob pointed out in a different thread that his model of winch is rated at the last wrap. I don't think they make that model anymore, or if they do, they changed the rating method. Anyway, I think that was the situation. He might remember better than me. I think it happened in the "skidding winches" thread.
Yes, wheelie niceNice load:thumbsup:
It is pretty meaningless to spec the pull on the last wrap unless you also spec the length
and diameter of the cable that is remaining on the drum when you make the pull so in Rob's case they must have done that I assume. Specing on the first wrap makes it independent of the cable.
gg
