Second video...
Nice setup for jockeying smaller material!
Second video...
One final, final opinion: Keep the SCUT away from the logs. It was never meant to be wrangling heavy stuff like that. The potential for hurting you or the equipment is too great.
For less than $50 you can buy 20' X 5/16" of Grade 70 transport chain at Home Depot or Lowe's. This is in the HARDWARE/TOWING section, in a bag. Chain will have grab hooks on both ends. Replace one grab hook with a Grade 70 slip hook ((think CINCH)) and you are ready to drag out logs from the center drawbar on your heavy L6060.
Tractors are designed to PULL. With low, low gears, big rear wheels for mechanical advantage and 4-WD you will be able to drag 85% of your tree trunks whole, after limbing them. The heaviest 15% may require limbing then one trunk cut to reduce weight.
Use only Grade 70 chain, which is much stronger than lower grades.
5/16" chain in Grade 70 is amply strong. 3/8" is much heavier/tiring to drag around.
You will want a clevis grab hook attached to the tractor center drawbar for securing the chain "easy on/easy off" on the tractor end.
LINK: CountyLine Drawbar Hook - For Life Out Here
If this $70 investment does not prove efficient, consider buying a logging winch as Plan 'B'.
(( However, you need to consider the fragility of your cab. "With 260 ft of cable on the winch, the tractor seldom had to go off the trail." ))
I am with GRANDAD4: Keep the SCUT away from the logs. It was never meant to wrangle heavy stuff. The potential for hurting you or the equipment is too great.
Tractor in two pictures is a Kubota B3300SU/HST, 1,950 pounds, less than half the weight of an L6060.
It is a killer getting on and off the tractor a million times though. I don't think I would have the patience running a long cable out to snag the trees if I could drive up to them easier.
The consensus about how to clean up 6-8 acres of downed logs and debris was a 50+hp tractor, grapple, and skidding winch. (Assuming a tractor, not a telehandler!) I am looking at a Kubota Grand L6060 cab tractor, grapple, and Wallenstein skidding winch. Grab the debris with the grapple and move it to a burn pile. Use the winch for the big stuff.
I have some resistance about buying the skidding winch. This is mostly because I have never used one and am unsure of its capabilities, but also because I would probably rarely use it after this one time cleanup was complete. And, it seems labor intensive to constantly be off the tractor pulling out cable and hooking onto logs to skid. I also have a Massey GC1710 SCUT with a backhoe and mechanical thumb. In lieu of skidding logs out, do you think it is feasible that I could use the Massey backhoe to lift one end of a log, cut it in sections, then haul the sections away with the Kubota grapple? Or maybe lift the log using the Massey loader with a chain?
I do have some logs two feet in diameter. Obviously too big for a SCUT. These were decked up by my contractor who felled the diseased trees. But most of the cleanup logs are eight inch diameter on average. They are in a whole tangle of debris that makes up the 6-8 acres. Some logs are smaller, some larger. It seems many were wary of taking a shiny new cab tractor into such a mess, but if I have two tractors to clear some lanes to work with, along with some patience and caution, I'm guessing I could get it done without a winch.
Considering these circumstances, would you spend the $$$ to purchase a skidding winch?
