Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #401
So, add them all in... lol
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #402
My massey gear is a dripper.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #403
There lies another problem, there's 50 yr old gear tractors, I bet many of them leak, but should they be counted? I don't think so...
A FAIR pole would be VERY hard to do as some hydro tractors are having problems, and it's hard to single out if it was caused my the loader or the hydro??
SR
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #404
SR
SR
A fair pole is easy to do.
If your tranny ever failed, was it gear or hydro?
What failed, just because we'd like to know.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #405
We would also need to know the number of tractor years represented in our HST sample and our gear tractor sample. We need equal tractor years in each sample. If not equal we can weight the results. We also need some way to match the tractors selected for each sample to make sure confounding factors do not make our results meaningless.
In short, any poll we do on TBN will be meaningless :laughing:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #406
I've never had issues out of either transmission on a running machine. A gear tractor still has oil, so a leaky hydro doesn't count. I have more hydros than gear.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #407
Sounds like hydro wins by forfeit.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #408
just like most other recent polls.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #409
Five tractors over the last 30 years, Two gear, Three hydro. No trouble from any of the transmissions.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #410
I'll join in this meaningless poll.
I've owned 12 tractors. 5 hydro. 8 gear.
No complete hydro failures. 2 hydros that got so weak I quit using the tractors and gave them to my Sons for parts.
2 clutch replacements on the gear tractors. 1 transmission seal.
Now that I have polled, I get the privilege of declaring my disclaimer. This poll has no relevance because there is no clarity on size and work accomplished with each tractor. For example, my gear drive Kubota has exerted more work energy in it's 1000+ hours than all the rest of my tractors combined with no failures of any kind. Second in line would be my 30 year old Ford which has approximately 4000K hours of field work with a clutch replacement. Whereas my first hydro, a JD 140, only mowed with a 42" deck (I think), and the hydro got so weak it would barely climb a grade in the yard. But since the hydro didn't completely fail and the Ford's clutch did fail this poll is going to chalk one up for the hydro. :)
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2017 Ford F-250 (A55973)
2017 Ford F-250...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
2008 TOYOTA Sienna (A56859)
2008 TOYOTA Sienna...
