Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #141
I guess you have indoor plumbing because you're too lazy to walk outside to the outhouse.
Was that aimed at me??
You mean you townies don't go to the bathroom out doors?? Indoor plumbing is over rated!!
I'd MUCH rather go outdoors!!
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #142
As the HST gets even more complicated (because they can) with electronics and bells and whistles it only makes the case for the manual transmission more attractive. Less expensive, is way more simple to repair (HST might even be repairable without dealer help and special tools and sophisticated hydraulic measuring tools and meters), DT is easily straight forward mechanical repair, expectations of fewer problems. You put it in gear it moves. HS
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #143
SR
Even when it's 3am, and is -10 degrees with snow on the ground?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #144
The better geared transmissions have electronics. I've never heard of someone breaking either transmissions. A clutch is far more likely to give trouble. Although a HST has a clutch it's not used.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #145
Keep in mind, I lived in Alaska for 25 years... Is -10 even winter???
SR
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #146
That doesn't help the case. Now you're just arguing for the sake of arguing.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #147
I agree the simple gear transmissions are easy to repair and are bullet proof for the most part. Hydrostatic transmissions seem to be bullet proof too and have fewer parts than the direction reverser transmissions. I have followed the TBN threads for several years and from what I gather none of the transmission types have many problems. All seem pretty bullet proof.
Electronic add ons and features/options, while some are handy to have the more of them you have the possibility of failures does go up. This is true of all tractors with options and features whether hydro, gear or IVT.
I waiting for a manufacturer to come out with a direct drive tractor with a reversing engine with a wide rpm range.:thumbsup:
Oh wait Mercury outboards tried that over 50 years ago and it was a failure.:rolleyes:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #148
Were there even HST's when my tractor was built? (1981)
Including the new tires, and mower (the mower was purchased new) I have about $12K in my gear shift tractor.
I can not even imagine what a 60HP HST tractor, and that mower cost today,,, :confused:
My old gear drive has served me well for 20 years,,, the mower for 10 years,,,
I think I will keep them!! :thumbsup:
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #149
Every commercial front end loader and backhoe I've ever run were torque converter power reversers.
That's what my Case has, and it's a really nice system. It's not quite as easy to use as an HST setup, but close in most situations.
As I've mentioned in another thread, when you make a mistake (foot slips, etc) with an HST machine, either nothing happens, or it stops moving. When you make a mistake with most any other kind of setup the machine keeps moving and something winds up broken or dented. Unfortunately, other than my wife and my mother, I don't know anybody who's perfect, and we all make mistakes.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #150
International Harvester built the model 100 Hydro in 1973-76, the model 186 Hydro after this followed by the 3488 I think. So yes hydro transmissions were available when your tractor was built.
JMR 96in Forklift Safety Basket (A56857)
JMR 96in Forklift...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
1605 (A57192)
1605 (A57192)
2016 VOLVO VNL760 TANDEM AXLE SLEEPER (A58018)
2016 VOLVO VNL760...
Yellow Posts (A55973)
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
