Gear or Hydrostatic Transmissions for Compact Utility Tractors?
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #101
Richard,
I would say that an Ehydro and the HST plus transmissions are smoother than the smaller mechanically controlled hydro transmissions.
And a hydraulic clutch is smoother than the mechanical controlled dry disc clutch. :)
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #102
Exactly opposite to my experiences.
And to the M8540 fellow on here - TripleR
The several wet clutches I have used have had a shorter engagement window than a typical dry clutch. The "feel" also tends to change more depending on how hot the fluid is. Not as much with the dry clutch, imo.
Anyway...
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #103
On level ground the higher center of gravity for the benefit of increased visibility isn't a problem.
Yeah, that's a great concept until you hit a soft spot, unseen hole, or a rock hits the wheel rim just right and the tire goes instantly soft...tractor on it's side despite all the ballast, etc. Obviously, that can still happen if the loader is low, but it's far less likely than when the loader is up high.
For someone who's broken a bunch of stuff on his tractor, I would have guessed you'd plan for the worst :confused3:
The creeping thread is still there if nobody else has pointed that out (I haven't read all 11 pages because there's nothing new in it).
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #104
My pickup is auto- only way I could get a heavy enough transmission for towing on my silverado. The stiff springs make it feel almost like a standard! My tractor is a gear 9x3. I like standards over automatics of any kind. I like the direct response to the gas and clutch. On snow- I really like that. I used to have a 5 spd on the floor chevy and that was fun to drive - and good for towing. Manual gear or auto/hydro- all a matter of preference.
My son's Mazda Mx-5 is a manual 6 speed. You get to 55mph doing 6 clutch shifts. Fun to drive- keeps you alert and gives you something to do so you are not bored! This is the shift pattern: Capturdddddddddddddddde.JPG
On level ground must have a different meaning for you than it does for me. I'm traveling down a road. A road.
As I stated, "If I'm on a hill, I make all reasonable efforts to lower my machine's center of gravity to increase stability and traction for any given load. On level ground the higher center of gravity for the benefit of increased visibility isn't a problem."
If you cannot accept that statement, you'll just have to accept that in my area roads and well manicured yards are flat and level.
See how I've got my loader down in the photo? It's because I'm not traveling over level (i.e. smooth) ground.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #106
HST ALL THE WAY, GEAR IS SUCH A PAIN THE *** WHEN TRYING TO DO ANYTHING
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #107
You don't think you can be on a perfectly flat piece of land and hit an unseen soft spot, or have something puncture the tire sidewall or something similar??? With the loader up high, it doesn't take much to put the tractor on it's side....even on level ground.
Arguing over what is, and what isn't "level ground" is simply playing with words to try and defend a silly position.
Like I said, with all the damage you've managed to do to your tractor, it would seem you'd know "stuff happens" even when things seem pretty safe.
   / Gear or Hydrostatic Transmissions for Compact Utility Tractors? #108
HST Gear Wine!
That demo means nothing to me... I don't test my tractors driving up and down a road in high gear...
My tractors get pto work, the REAL test for hydro whine is, put something on the pto like a tiller, rev the engine up to pto speed and run the tractor at 1.5 mph, 2.0 mph and about 3.0 mph. Those are the most common speeds I do pto work, from rotavating, rotary cutting ect...
Every hydro I get in, that I simulate doing that, the hydro whine drives me nuts! I can't imagine putting up with that for hours on end!!
When I run my loader, I have the tractor at fast idle, and use a gear that moves me from the pile to the spreader fairly fast. Gear drive allows me to use fast idle and still have enough power to load the bucket at the pile.
NO hydro whine, NO loud roaring engine noise, and the diesel sips fuel all day long at the fast idle rpm...
I do like a hydro for mowing grass though... The blades make enough noise, it drowns out all other noises, so I wear ear plugs, with muffs over them.
BTW, I don't and won't drive my tractors with the loader up in the air either!!
SR
I do like a hydro for mowing grass though... The blades make enough noise, it drowns out all other noises, so I wear ear plugs, with muffs over them.\
SR
PTO work? Okay. There isn't any HST wine while running the PTO. All recorded from inside the cab.
There isn't any HST wine outside of the cab either when using the PTO.
The only time I ever hear the HST is in high gear.
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2017 GMC SIERRA 1500 (A58214)
2017 GMC SIERRA...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A58017)
2012 INTERNATIONAL...
2014 Toro Groundsmaster 4500D Commercial Rotary Mower (A56857)
2014 Toro...
