   / Your last generator Maintenance Run
Speaking of maintenance runs... it's been awhile since I pulled out my 6hp Merc outboard motor. I think I shall do that today.
Collateral Maintenance happening..... I'm cool with that ! :) :thumbsup:
Rgds, D.
   / Your last generator Maintenance Run #852
I知 currently in the process of repairing a 10hp Yanmar diesel clone in a generator that has 220 hours on the meter.
It was purchased for home backup and was being used on a job for 3 weeks running skil saws, sawzalls, a compressor and battery chargers.
It had run fine for weeks approx. 8 to 10 hrs. a day when it started skipping, blue smoke and various noises.
When I received it I tried to start it but it appeared to be low on compression and would not fire.
I pulled the oil filter screen and it was full of junk & sludge.
The owner said he wasn't aware of the filter because the manual got ruined in his cellar due to moisture where the generator is stored.
Further inspection and details of how the owner operated it indicates it may have been wet stacked from running in the winter with not enough load to warm it up.
I removed the engine & disassemble it and found 3 patches of rust on the cylinder wall but no scoring.
The exhaust port was wet from running with little load.
I removed the piston & rings which look good with no obvious defects along with all other components.
There were some deposits in the bottom of the crankcase but nothing serious.
I remove the valves from the head and saw some pitting on the exhaust seat so I cut new valve seats with my Neway seat cutter. I resurfaced the head on my granite surface plate using 220 wet/dry carbide paper.
Cylinder was honed which removed the patches of rust but pits in the cylinder wall remain which should be ok.
New parts installed are;
Piston rings, pto main bearing, rod bearing oil filter screen and various gasket & seals.
The block is built and the head is on and I'm trying to torque the flywheel nut to 150lbft of torque, I don't have the moxie anymore and I need to find some young muscle to help.
Further discussions with the owner indicate that he has no idea how much load he can put on it.
During an outage in the winter he basically runs the circulators for his hot water boiler (heat) and some lights which may total 1kw at best.
Will update as progress is made.
90cummins
Do you fog your outboard or other fueled equipment at the end of the season?
At one time that was what everyone recommended... don't hear about anymore.
On a separate note...
Looks like the commercial 2 stroke Toro mower came out unscathed from a half tank of straight fuel.
Posted that it ran out of fuel and there was a little straight gas in a can that used to fill it half way...
Excellent Compression and sounds good when I added some Stihl Ultra to the tank.
Maybe 25 years of two-stroke fuel left enough residue for 10 minutes of run time?
Lady Luck smiles on you.... give her a wink and a nod for that Toro..... residual lube may have taken care of that short duration run.
Fogging oil is still around, but it seems mostly the boat and some classic-car guys that use it. Can't say that I use it on my stuff, but that is more laziness on my part rather than thinking it does nothing.....
I'd probably use fogging oil if I planned to store something long term, say longer than 8 months....
Rgds, D.
90cummins
Your shop needs some more resources.... or do you have a casting foundry out back too ? ;) :laughing:
Thorough rebuild - thanks for the details. IMO, diesels suffer the worst from under-loading - good example of the consequences.
From your description of the sludge and rust, it sounds like the oil was neglected too.
Post-rebuild, I hope your buddy has learned a lesson, and adds a couple of space heaters as load.
Pls let us know how fire-up and run-in/testing goes.
Rgds, D.
   / Your last generator Maintenance Run #855
PCB's are chemicals that were used in high voltage transformer oils.
They were dumped & buried in and around Pittsfield Ma.
During remediation of the contaminated soil air samples were taken 24/7 to monitor air quality.
In some neighbor hoods they went 10ft or more to remove soil.
There are also permanent pumps pulling a vacuum to extract oil that has moved to deep to access.
90cummins
   / Your last generator Maintenance Run #856
Rgds, D.
You are correct insufficient load causes a lot of problems, particularly with diesels. That's why you should have more than one generator.
One small generator for when consumption is minimal such as at night. This also saves a lot of fuel running s small generator for small loads versus a large generator at a low loads.
A 12kw propane generator may use 1 to 1.5 gph with no load. My Honda EU 2000i will run 8 hrs with a 300 watt load running the fan on my wood furnace and some LED lights during a winter night.
90cummins
   / Your last generator Maintenance Run #857
How often do you load bank your Diesels?
   / Your last generator Maintenance Run #858
A diesel is designed to operate at full rated rpms at full rated load continuous for hours at a time . Anything else is looking for trouble . Combustion chamber and exhaust temperature temperatures drop and clean combustion does not occur.
Partial loads and varying loads are best operated with a gasser.
   / Your last generator Maintenance Run #859
No particular schedule but when I start them to exercise I run them with a load for 30 minutes minimum.
I loaded my Honda EU2000i & ran it out of fuel because it was mostly idling while I painted and I wanted to purge the fuel system of all the old gasoline to refill with non-ethanol.
Yesterday I started a load test on my 24v battery backup system at 1:40pm and shut it down this morning after 18 hours to verify the battery capacity.
The voltage and specific gravity put the L16RE-B batteries at 65%.
I'm now going to use my 4kw L70 Yanmar diesel which hasn't been run in 4 to 5 months to recharge the system and time how long it takes to charge the bank then measure the fuel consumed. This will be the first time I've run the batteries down to recharge with my diesel.
My inverter will limit the load on the generator to 3500 watts.
In the event of a major outage I want to know how much fuel I will need to survive at least a week with no power using my batteries and generators while minimizing my electrical loads.
Will post the results.
90cummins
   / Your last generator Maintenance Run #860
90cummins
2022 BOBCAT T770 SKID STEER (A52706)
2022 BOBCAT T770...
7' X 8'8" MILITARY STORAGE BOX (A52706)
7' X 8'8" MILITARY...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55314)
2022 John Deere...
MINI EXCAVATOR BUCKET 32 (A55745)
MINI EXCAVATOR...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
