C4Ranch
What's the expected life of the batteries you all are using?
I think this is the big question on what the eventual ROI will be. How he uses/maintains the batteries is very important.What's the expected life of the batteries you all are using?
Just kind of guessing here, but it looks like your ROI will be about 10 years or even a little less? Nice setup and it sounds like you have learned a lot.
Any idea on how often you will recycle/charge the batteries... every day? twice a week?
I don't suppose you have a source of running water on the place?
Thanks! I've learned a lot and still there is an unbelievable amount of knowledge I wish I had.
I wasn't concerned with ROI, mostly with just simply creating a modular system that was capable of generating as much power as we could possibly use up here. No doubt over the next 20 years, we'll be upgrading and replacing components as well go.
At a minimum we should get a few thousand cycles from them before they really begin to degrade in performance. Our anticipation with these AGMs is we will only be bringing them down 20% to 30% per cycle rather than the usual 50% that is common when sizing a bank. This means we should get as many as 4000 cycles give-or-take and could even be more if we are gentle on our charging voltages.
~Moses
Not too gentle with the recharge voltage on AGMs. The Odysseys I use like 14.7V until the current uptake drops off. Then a 13.6V float charge to keep it topped up. Go to the Odyssey site and read their tech info about the preferred charge profiles. Too much voltage and they'll vent which will ruin your battery and make you really mad. I had one overvolted from a bad regulator and it swelled up like a toad turning it into a door stop.
By building on land that your local utility wanted stupid money to wire, from where I sit OP, you've already hit your ROI.
Living in a province that has set a goal of attaining California-like kwh rates, it is nice to see someone give their local utility a one-finger salute.
There is only one downside to successes like yours getting wide publicity - it can lead to jurisdictions passing "safety" legislation requiring grid connection for occupancy permits. Many people don't have the financial discipline and personal drive to accomplish a project like yours, but the utilities are definitely fearful of this approach catching on.
Rgds, D.
I was told that utility districts aren't fearful of solar panels, they are accepting of that technology, their real enemy is the storage of power, the evil battery bank.
~Moses
Lots of kudos and respect to you Moses! If I was on your side of the mountain and had some help (like yoursGood point.
My pride played a small part in it when I was told by the PUD sales guy that I couldn't make this work.
As for legislation, they tried a few years ago to pass a water meter bill here in WA state for private water wells. Additionally, they introduced but were not successful at charging an electric tax for off-grid properties. They attempted to convince people that off-grid properties are not contributing to the utility district and needed to do so with tax dollars.
~Moses
Lots of kudos and respect to you Moses! If I was on your side of the mountain and had some help (like yours) I would likely try the same. I studied solar energy engineering at UW back in the day and realized that the practicality wasn't there as long as I lived west of the cascades. Solar technology has advanced tremendously but global warming hasn't... so I will just drool over your system for now. :laughing: Looking forward to operational updates as you go along.
We NEED Pictures !!! Lots and Lots of pictures !!!
Wow this system is really impressive...
I built a *much smaller* system for a family i know who lives near Tonasket, WA off grid and just wow man. Good job!
I'll be back up there working on moving the solar panels for that system in early September in fact. (they were on the roof but i want to move them to ground mounts on the hill behind their building becuase it'll be more stable in winter).
I have no problem with someone that wants to go off grid. I would probably hook up in most cases if its available. I hooked up to rural water even though I have a good well. What really ticks me off is when they want to force you to hook up or tax you if you don't. Pretty silly. In my area they are still pretty fair about hooking up to the grid, often very reasonable.
