Most Useful Minor Additions to Tractor
   / Most Useful Minor Additions to Tractor #181
[The bale spear could be carried in a pipe mounted in the manner of my shovel carrier... (right side loader arm mount). Pointed end down!!
I can understand why he wants it- I have a heavy wrecking bar hung in the barn which I have used to good effect more than once, trying to get a heavy weight box attached.
ATTACH=CONFIG]465019[/ATTACH]
Nice mod. How is the tube attached?
   / Most Useful Minor Additions to Tractor #182
Deerslayer, the tube is steel pipe, and I simply welded a couple of pieces of scrap steel channel onto it (blow up the photo to see). They have bolts into threaded holes on the mount. I welded a cupped washer (from an old shock absorber?) on the bottom, so it has a drain hole.
   / Most Useful Minor Additions to Tractor #183
   / Most Useful Minor Additions to Tractor #184
Probably the least expensive and most used simple addition to my Kubota is a seat cover which prevents rips etc from tools in my back pocket.
   / Most Useful Minor Additions to Tractor #185
Great post! So many new ideas!
A rear steel basket (chainsaw ready!)
I just looked again at your picture because someone else just replied to your post here, and I wanted ask what is the purpose of the orange tape on your ROPS?
Just curious,
Thomas
   / Most Useful Minor Additions to Tractor #186
I ordered the two biggest ammo cans I could find, after search around. $30 in shipping, $25 each. I didn't realize how big they would be. One is so long I can't reach the bottom. I thought it opened at either end, but no.
One is for my side by side. The other might me to big for me to fit on the tractor.
25mm and 125mm mortar.
   / Most Useful Minor Additions to Tractor #187
I bought the short one to go on FEL frame by my knee. But I think it nay be to big.
Both may end up on side by side. Made my first load of wood with bucket. Probably use SxS less. Though it is nice just to buzz out quick, and can get back farther.
   / Most Useful Minor Additions to Tractor #188
A foam Koozie for my beverage (that fits snugly in the holder in the cab) and a small 12 volt cooler that sits on the floor for extra beverages and a sandwich. I spend long days in a tractor.
   / Most Useful Minor Additions to Tractor #189
Fabbed up an extra step to climb on my old 861D Ford. My worn out knees love it.
In the hole in the dash where the optional dash light went in 1958, I installed a 12 volt plug (diesels were 12 volt back then). I normally keep a cheap DC meter plugged in there for constant voltage monitoring, but can easily be unplugged and any number of 12 accessories could be used, like tire pumps, fuel transfer pumps, radios, lights, etc.
I added a hydraulic gauge to my pump for constant monitoring of my hydraulic pressure.
I bolted a pipe to the back of the seat so that I can drop in an old patio table umbrella for rain or sun protection when needed. The seat was also an upgrade as the old Ford's original pan seat had no back support and could have easily flip me off backwards a couple times if I had not had a firm grip on the steering wheel.
I just recently added a set of the Pat's Easy Change hitches to my arms. I would have preferred the beefier Quick Hitch, but all my old implements are non-standard and very few have the same measurements between the pins, much less having a top-link that was set-up for a hook. This was a big help in attaching some of my heavier implements like my box scrape and bog harrow. No more pulling and tugging to get the ball & sockets and sway arms all pinned together.
   / Most Useful Minor Additions to Tractor #190
Not sure if I would go cheap on DC voltmeter. A tenth of volt can tell you alot.
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A55788)
2019 Ford F-550...
1000 (A47477)
1000 (A47477)
2020 Kubota BX23S TLB Compact Tractor (RIDE AND DRIVE) (A50775)
2020 Kubota BX23S...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
