Buying Advice Live PTO vs. Over-running Clutch vs. Slip Clutch
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #11
I think it gets called a clutch as it essentially clutches int he opposite direction, or when the implement overspeeds the tractor.. IE a 1-way clutch or ratchet. to save confusion from the newbies with the differences in that an a slip clutch.. the 'coupler' term seems safer.. to me anyway..
soundguy
Just to complicate this discussion, my MF-124 baler has a conventional slip clutch (like you find on brush hogs) along with a sprag clutch that's built into the slip clutch. The sprag is a one-way clutch that only transmits torque in one rotation direction. In the opposite direction of rotation, the sprag free-wheels.
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #12
Yes, that is how I remember it on the MF balers. A baler sure could supply a good amount of inertia if it was allowed to.
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #13
sounds like a slip and over running all together in one.
my IH belly mower on my 66 cub has a built in orc in the mower drive pulley at the hub for the blades...
soundguy
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #14
Flywheel effect..........have you see a tractor running into your car and the operator can not stop the tractor intime ? That is without a ORC !
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #15
I'm looking at old tractors in the 20 - 30 HP range and have been receiving advice in another thread. (Ford vs. Case)
I've gained a new perspective in regards to LPTO, however I am receiving some interesting information from sellers and tractors. I've been looking to confirm whether tractors had the overrunning clutch, and have noticed others identify a slip clutch.
Can you help me understand if these are the same thing? I'm gleaning that I can add a $60 slip clutch to any tractor's PTO. Is the "over-running clutch" a factory feature of the same intention?
I'm looking at a lot of late 40, early 50 Fords and other makes, but trying to stay under 3K. Not finding many of the later Fords (861) with Live PTO, but if I can add the slip clutch for the same effect, it opens up many options.
Thanks in advance.
For under $3000 you can find a tractor with live pto, a real drawbar , working brakes , live hydraulics and it's less liable to roll or flip than a N series Ford.
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #16
N series fords are no more prone to tip, roll or flip than any other brand with similar layout.
Its usually the moron driving that causes problems
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #17
Why are so many N series Fords upside down on top of their drivers?
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #18
Like the previous poster said, the moron driving. Usually trying to pull a heavy load with the three point hitch rather than the lower drawbar.
   / Live PTO vs. Over-running Clutch vs. Slip Clutch #20
Moron drivers.
Given that most small 4 wheeled tractors with a 3pt hitch and hp rating from 25-40 and similar weight range perform practical identical regardless of paint color or name badge.
Since you are singling out ford, it signals that you are just hating on fords, or dont understand the dynamics of the problem, or both.
VIDEO LINKS FOR ALL LOTS W/ VIDEOS (A59213)
VIDEO LINKS FOR...
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
gps trailers (A56859)
2022 Horizon Trailer (A55973)
2022 Horizon...
2757 (A55787)
2757 (A55787)
NEW Fork Extensions (A59000)
NEW Fork...
