Lets see your Woodworking Skills
   / Lets see your Woodworking Skills #101
I've done decent furniture stuff, but I find working with reclaimed wood (i.e. dirty, full of nails, cupped, rotton, etc.) is much harder to deal with. Here are a couple of pieces using wood from a pig barn that collapsed on my property
Tilt out garbage can holder:
Coffee table trunk with hand cut dovetails and elm wood top from the barn:
IMG_20150213_071655_465.jpg IMG_20150213_072515_866.jpg IMG_20150213_071605_648.jpg
I also used acid to strip the hardware and gun bluing material to make the black oxide handles. Turned out great! Fun project.
   / Lets see your Woodworking Skills #103
The mantle and the table came from the same maple tree from my bush lot , and the stools from another smaller maple. All gifts for my daughter's rural house.
Dang, I forgot about my own thread!
Here is a small kitchen island I just made for my son's apartment out of an old desk.
View attachment 464676 View attachment 464677
View attachment 464681 View attachment 464682 View attachment 464683
Nice hand cut dovetails. Nice work!
   / Lets see your Woodworking Skills #107
Here's an 1890's coach I recently restored.......
   / Lets see your Woodworking Skills #108
Wow, nice restoration!
   / Lets see your Woodworking Skills #109
Jerrybob, not sure what part of the hood you are in but hello. WOW, that restoration is amazing. One heck of a project. How bad of shape was it in?
   / Lets see your Woodworking Skills #110
I love the look of a slab table with a live edge. Is there any trick to stop them from cracking after you cut them?
I have experimented with lots of tricks. The main thing to do is slab up the logs and have them dry in
a somewhat controlled manner. The worst thing you can do is to leave them as large thick pieces (>6"), which
allows the outer parts to build up tension stresses as it dries. If you can make the inner part dry faster
than the outer part, then maybe you can reduce the checking. Maybe.
Chainsaw millers regularly slap some goop on the ends of their slabs. It is expensive stuff. I suggest
using melted wax from a candle. Again, outer drying that causes checking is much more of a problem
if you leave the logs in large pieces with removed bark.
One of the "goops" I use is latex paint on the ends while letting the logs/lumber dry, about $9/gallon at Home Depot/lowes on the "whoops rack".
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
