SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,395
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I was wondering if a furniture dolly would work?
That's a great tip! Thanks.
You are correct! Problem is I'm not sure the boom for the engine hoist under the fender and still get the tire off.
Has anyone actually used an engine hoist to do this?
I am well aware that once it starts to tip I will not be stopping it and could easily be injured in the process. I don't take that lightly (pun intended!)
Lots of good tips and lots of problems can be reasonably extrapolated from most. -- The problem is that many will cause instability. Assuming the tire will fall over if you dont hold it, any instability will be your enemy. You cant have a wheel that heavy moving when you dont expect it. So tire dollys and grease can turn into a real problem if the tire leans and slides/moves -- youre suddenly chasing it. -- And "dont let it lean" is an absolute danger. The tire must lean toward you slightly. If it starts to lean away your chance to save it disappears almost immediately.I may have to resort to that if I can't get them back on! Lol.
,,,Simply rolling the tire is the safest un mechanically supported method. - You can adjust the tires position in a fine manner when removing and installing by using a combination of swiveling and rolling back and forth. Dont forget you can turn the axle hub to help line up holes. - ... - Now, the engine hoist method is a piece of cake. You can chain or strap the rim such that as you lift you can tip the top of the tire out to a stable hoist supported position leaning away from the tractor with the tire tread resting on the floor. Lift a little more and take it where you want it. -- For reassembly the same lean aspect would be duplicated so you could rest the tread under the hub just right so as you push/lift the tire upright it mates perfectly.
