B2650 MMM install?
/ B2650 MMM install? #1
Rob 80
WVA
B2650
I just installed my 60" MMM does anyone have any tips to install it with ease? My trouble is the deck is so heavy it's hard to get it into position by yourself to mount since the rear wheels of the deck do not rotate. I also had trouble getting the mid pto hooked up since you can not really see the teeth to align them i just guessed.
/ B2650 MMM install? #2
Do you have a front loader? I keep mine on until after the mmm is on or off. Then remove for the lawn season. It jacks the front wheels out of the way. My shop floor is smooth and I put a low dolly under the mmm for any direction movement. Hookup is just muscle , and I too am losing it!
Rob
/ B2650 MMM install? #3
Have the 72 but it has swivel wheels on each corner. Use the loader to lift the front and muscle it in. I just drop the bucket or grapple and leave the loader arms on to mow.
/ B2650 MMM install? #4
Rob 80. The best way to do remove or install the 60 in mmm is to lower the 2 front bogey wheels to raise the front of the deck. The left rear anti scalp wheel has another hole in the shaft to drop it down and turn it 90 degrees. Then lift the rear gauge wheels all of the way up so they dont drag. The deck will sit on the 3 wheels and will be above the right rear anti scalp roller. After unhooking the brackets and pto shaft turn the tractor wheels all the way to right. You can then pull the deck out the right side. It might take a little wiggle to get it around the front tire. You can basically pull it out with one hand this way. I can remove or install mmm in 3 or 4 minutes this way. 20160216_165104 (450x800).jpg
I do have a loader and use it to get the mmm to clear the b2650 chassis it only has to lift the front of the tractor a inch or two. rkidd idea would take care of that.
It takes me forever to get the pto on because you can not really see it to align it up, i just guess.
/ B2650 MMM install? #6
Rob 80. For the mmm pto I slide in from the back of the tractor and that way can see the splines to hook up shaft. Hope this helps.
/ B2650 MMM install? #7
I've hooked up the mid- PTO from the side, but it is easier to just lay down on the ground and slide under the rear end, just as rkidd does.
/ B2650 MMM install? #9
Getting the splines aligned is a pain - a three-handed job. Trying to "eyeball" the alignment while holding both ends of the connection while ALSO trying to employ the third hand (elbow, knee) to find the magic spot where there is just enough pressure that the male end will slip into the female end without either binding or separating seems harder than it should be.
One thing that's helped is marking the correct alignment of the splines. I use a drill to create a light, but lasting, mark to help align them.
Granted, it's a relatively small inconvenience but it just seems like a really, really easy engineering fix for Kubota. Never used another brand so I can't compare to others.
Yes you would think they would mark the two ends to make it simple.
/ B2650 MMM install? #11
On my old B2410 I made a dolly for the MMM so it would roll around with ease. You don't have to do anything with the wheels on the deck itself. Sorry I have no input on the pto shaft. Marking both side seems like it would be a good solution as other have said.
Good luck.
John
/ B2650 MMM install? #12
After a few years of the same kind of struggling with the 60 inch mower on my B7500 I made a little modification that allows the mower to be easily rolled in from the side. As mentioned, I do keep the FEL on to lift the front end to also made install easier. Connecting the shaft can be a little frustrating but I think the easiest way is to lay down and approach from the rear. You can read about my MMM mod here:
http://www.tractorbynet.com/forums/...ore-mmm-back-pain.html?highlight=#post2804425
/ B2650 MMM install? #13
Its a pain no matter what you do, its even worse with any shield underneath. I dont understand why the scalp wheels cant swivel? It is nearly impossible to pick the thing up to switch their direction, very frustrating, and probably a reason I would consider another brand next time around.
/ B2650 MMM install? #14
Maestro71. The anti scalp wheels on the 60 in mmm for my B2650 do have holes to pull the pin and turn them 90 degrees. Not sure if if yours is the same for the bx but if not you could maybe drill new holes in the shafts to be able to turn yours 90 degrees. It makes it easy to remove deck that way and I can pull mine out with one hand. I do have to amend my procedure on the removal of my deck. I stated to turn the tractor wheels all the way to the right but should have been all the way to left to open it up to remove and install deck. I put my deck on yesterday to mow and realized my mistake.20160216_165104 (450x800).jpg
/ B2650 MMM install? #15
I'm thinking about pulling the trigger on a new 2650 cab with 60" mower and my dealer told me the 60" mower is drive-over. By the subject of this thread, I take it he is mistaken (I don't think he's purposefully trying to mislead me, but I was a little surprise when he told me that). I did find a youtube video on a Kubota drive over mower, but it clearly wasn't the 60" mower being referred to in this thread. There is very little info on either B50 series mower on the Kubota web site. If the rear wheels on the B50 series mowers do turn 90 degrees, then I don't think I'll have much of a problem removing it (as rkidd has suggested), but would like to clear up the drive-over question before I buy.
/ B2650 MMM install? #16
Maestro71. The anti scalp wheels on the 60 in mmm for my B2650 do have holes to pull the pin and turn them 90 degrees. Not sure if if yours is the same for the bx but if not you could maybe drill new holes in the shafts to be able to turn yours 90 degrees. It makes it easy to remove deck that way and I can pull mine out with one hand. I do have to amend my procedure on the removal of my deck. I stated to turn the tractor wheels all the way to the right but should have been all the way to left to open it up to remove and install deck. I put my deck on yesterday to mow and realized my mistake.View attachment 463059
My 04 BX23 w/54" MMM has anti-scalps that can be rotated as you stated, make it far less painful as these things are pretty heavy....I've taken mine off and re-installed it without rotating the rollers...It can be done, just much more work.
/ B2650 MMM install? #17
Scott F I just checked my mmm owners manual and it says to install 60in mmm just the way I describe in my post from the side. It does say however to drive over the deck for the 72 in mmm to install. Hope this will help. Any other questions let me know. Good luck on your tractor purchase. You will love it.
/ B2650 MMM install? #18
Thanks, rkidd. That's exactly what my dealer said after he dug some more into his Kubota books. I still think I'll stick with the 60" deck, just for the price. At the rate I pay myself for mowing, it would take a long time to recover the cost difference in time saved with that extra foot of mower deck :). Do you have any problems with the real gauge wheels digging into the turf when turning? I usually 3-pt turn at the ends of my lawn. Looks like some fatter, rounded rear gauge wheels would be gentler on the grass.
/ B2650 MMM install? #19
No problem with rear gauge wheels. They are in the center so they sort of turn on they're own axis versus being out on the edge where there would be more pressure on them when turning sharp. The deck mows great and I have been very happy with it. As far as a little more time to mow versus the 72 in deck it is always great to spend extra time on the Kubota! !
/ B2650 MMM install? #20
Funny they made the 72" a drive over and the 60 is not? Especially when the 60" on the B2610 and the old B20 series were drive over.
So does the 72" on the B2650 bring any limitations as far as implement compatability?
To me sounds like the 72" would be the one to buy for that model.
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
iDrive TDS-2010H...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
