What do I need for a 50 hour service on a DK45SE
   / What do I need for a 50 hour service on a DK45SE #1
vanguard
Raleigh, NC
2014 Kioti DK45SE
My DK45SE is about to hit 50 hours and I need a parts list for the service. My deal said it would be $700 to do it or $500 for just the parts. That feels high to me.
Is there a list of things I need to buy? I'd like to avoid his markup.
   / What do I need for a 50 hour service on a DK45SE #2
Is this a gear model ?
Assuming your changing hydraulic fluid,
$150 or so in transmission fluid
$35 hydraulic filter.
$20-$30 engine oil
$10 oil filter
I'd be guessing closer to $220 area doing it yourself if changing the transmission fluid (gear drive machine).
Shouldn't need a fuel filter or air filter at 50 hours IMO.
   / What do I need for a 50 hour service on a DK45SE #3
For what it's worth, the 50 hour service is the most important one, IMO. My one tip would be to throw a big piece of cardboard under the tractor so you can slide in and out easily and stay clean.
   / What do I need for a 50 hour service on a DK45SE #4
Was he going to change the hydraulic fluid and front axle also.
   / What do I need for a 50 hour service on a DK45SE #5
Oil filter E6201-32443
HST filter T4125-38021
HYDRAULIC T4620-38032
Fuel 84612-43160-0
Air Filter E7230-11081
Donaldson P822768
Fram CA9246,
Fleetguard AF25308,
Napa 6489,
Baldwin RS3988,
Carquest 88489
Luber Finer LAF8143,
Wix 46489
   / What do I need for a 50 hour service on a DK45SE #6
The hydrostat filter is the real killer, at near $90. If HST. otherwise if gear you wont need that. Air filter can probably be cleaned. I use a vacuum cleaner from the outside. Fuel filter probably does not need changed.
Fuel 84612-43160-0
Donaldson P822768
Fram CA9246,
Fleetguard AF25308,
Napa 6489,
Baldwin RS3988,
Carquest 88489
Wix 46489
Oh my gosh, this is so helpful. Thank you.
It's a gear transmission, not a hydro. I guess I just don't need that part? Or do I need something else?
   / What do I need for a 50 hour service on a DK45SE #8
You won't need the HST filter. Good news that is the expensive one. Be sure to cross check at the dealership as part numbers do change from time to time. The first air filter number the E number is the Kioti part number, but it IS a Donaldson. the rest are cross checks of other brands for that part number. I change them out once a year, but at 50 hours you should be good to just clean it. With a vacuum cleaner on the outside of the filter. Hold it up to the light and check all over for pin holes. if none put her back in service after cleaning all the dust out of the housing with a damp rag. Make sure the housing is very clean on the inside.
   / What do I need for a 50 hour service on a DK45SE #9
That's expensive... folks should think like the Donald and negotiate an amazing deal on the 50 hour maintenance work at time of purchase :)
   / What do I need for a 50 hour service on a DK45SE #10
I was going to mention this, but didn't want to gloat, but I got my dealer to throw in all the filters I needed for the 50hr, including the HST. I am happy to be able to do it myself the first time and use the fluids I want.
2013 Kia Soul Hatchback (A55853)
2013 Kia Soul...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
