Broke front hub
/ Broke front hub #1
GPintheMitten
Elite Member
Flushing, Michigan
Kubota B2620 with BH65 backhoe, Ford 2N
On my Kubota B2620, I broke the left front hub. I don't know what exactly caused the failure but nothing a thousand dollars can't fix.
uploadfromtaptalk1456353198187.jpguploadfromtaptalk1456353210987.jpguploadfromtaptalk1456353225727.jpg
/ Broke front hub #2
Sorry about your loss... stuff happens when you actually use things. I pushed my hood back some a year ago hauling a big stump on my forks. Time to plead with the wifey for a back up tractor... [ especially with today's snow ]..
Worth a try.... !!!!! :)
/ Broke front hub #3
Show her this picture... it will either help some or HURT A LOT....
/ Broke front hub
They asked me what I was doing. I told them I was using it. I've never had a truck, tractor or other equipment break while parked in the driveway.
Actually I was spreading gravel at my daughters farm. About 5 hours of getting a loader full of gravel, driving down the lane then dumping it and spreading it. Back and forth.
I did see a nice B2650 cab in the showroom but hard to justify the $26000.
/ Broke front hub
Good one jerryk. I saw that before, but now it applies to me.
/ Broke front hub #7
So sad, do we need to send flowers or do you have a charity you'd rather us send money too. Not many of these tractors in the junk yard so might be hard to find used.
/ Broke front hub
The hub casting isn't brok, just internal parts I think.Don't send flowers. Send warm weather. Ha ha.
I think hours are around 600.
It was a good time to take a crap. Now my soninlaw is out plowing about 10 inches of snow with his tractor.
/ Broke front hub #11
What were you using for ballast?
/ Broke front hub
I have the rears loaded with Rim Guard and had a blade on the back.
/ Broke front hub #13
/ Broke front hub #14
Call Messicks, order what you need, take photos as you repair it, don't do it again! Shouldn't 'a happened, though.
/ Broke front hub #15
Were you running in 4wd? I would think gravels would provide enough slippage, but it is possible it was binding.
/ Broke front hub
Funny the way things go sometimes. A few days ago, my daughter called and said 2 gravel trains were coming and could I come over and help. Well I have recently converted my loader to SSQA and had the fel part done but had not got around to welding the plate to the bucket.
So after I hung up the phone I went and spent about 4 hours out in the shop welding it up. Trailered it over to her house the next day and proceeded to break it.
Oh well, I got the money to fix it. She wanted to pay for half the repair bill. I told her No, it would have broken at home if not there.
/ Broke front hub
I was in 4wd, on lightly snowed and wet gravel and some mud.
I'm not sure what failed first. I'm having the local dealer fix it. Probably about $300 to 400 labor. I would rather them fix it.
/ Broke front hub
If you think tractors can be expensive, try horses or sailboats. I sold my 30' Catalina a few years ago so this is I can handle. lol
/ Broke front hub #19
Ain't nothing worse than a Boat, unless its a Airplane.
/ Broke front hub #20
Boat = Bring On Another Thousand.
Hay Feeder (A66408)
Hay Feeder (A66408)
Madvac CS500 Litter Vac (A65579)
Madvac CS500...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
2002 Sterling L7500 Series VacCon Combination Sewer Jetter Vacuum Truck (A64556)
2002 Sterling...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
