Warming Predictions
/ Warming Predictions #41
The nice thing about any change, we really have no clue if the result will be better for man kind or not better. It could just be "different".
We keep encouraging our children to "make a difference", "embrace change" etc, But many people seem to be all wound up and troubled when the power goes out.
Life isn't easy every day, but it's not that hard either.
Live responsibly!
#1 - I saw a Prius the other day. It was stopped off the side of the road. It's driver was walking away from it with a gas can in hand. Think about that for a second if you have to. A hybrid vehicle out of gas and electricity at the same time and it apparently happens so often that the driver carries a gas can?!?! I would have given him a ride to the station but he probably would have gotten mad at all the laughing I was doing.
So, you have seen a Prius! Interesting that for such a car you even recognized it!
Seems one can see often see cars on the side of the road; even ones that are not Prius!
/ Warming Predictions #43
I wonder...if all cars were electric, could we ever produce enough electricity to charge them.
I doubt it. Even if we could, how much fuel would it take to do it?
Electricity is a very inefficient use of fuel with all the losses it encounters every time it is changed to something else.
assuming we have the fuel and don't take creation of fuel into consideration:
using electricity to power a car:
fuel burns...one loss of energy.
creates steam.. one loss of energy
steam turns turbine... one loss of energy
turbine creates electricity....one loss of energy
electricity moves over wires....one loss of energy.....actually many losses due to resistance and switching
electricity changed to DC in car battery charger....one loss of energy
electricity turns car motor.....one loss of energy
using fuel directly in car:
fuel turns car motor...one lost of energy
The green weenies just don't get it.
/ Warming Predictions #44
Of course I recognized it. I'm a bit of a car guy. You do have to admit that a lot of the hybrid vehicles wouldn't be sold if it wasn't for the huge tax credits.
I did/do feel bad laughing at the situation. I don't wish a roadside failure on anybody. But it does raise an interesting point. If one has an all-electric vehicle (Isn't the Volt all electric?), how does one get it going if you run it entirely out of fuel? Are we going to have to have gas powered generators to be able to charge a stranded electric vehicle?
/ Warming Predictions #45
This isn't quite as impractical as you assume. I don't foresee an all electric car scenario anytime soon, but the total energy use in the transportation sector is only a little over half of the current electrical energy use. By increasing the number of power plants by 50% we could at least switch all passenger cars to electric. There is a potential silver lining in this also as most charging could probably done off-peak, at night, allowing more of the power plants to be base load and minimizing the stress on the electric grid (distribution system).
The efficiency impact of electric cars is pretty complex. Gasoline engines are limited to thermal efficiencies in the 30 to 35% range, as I recall and there is no mechanism for regeneration (capturing braking energy). On the other hand, electric motors can easily be 95% efficient and allow regeneration. On the electric generation side, coal plants typically have over 40% thermal efficiency and combined cycle gas plants can exceed 60% thermal efficiency. Losses in transmission are generally less than 10%. I don't know what the charge/discharge efficiency of the advanced batteries would be now. If the electricity is generated by wind, solar, nuclear or hydro, the efficiency probably isn't something to be considered, only cost.
The modern internal combustion engine is a marvel, but there are efficiency limitations in the Otto cycle (and it's offshoots) that will keep it's efficiency well below a central station power plant.
I do not know what the remedial action would be but it may be similar to what happens to a conventional vehicle which has stopped running while being driven on the road.
As an aside do regular vehicles ever run out of fuel while on the road??
/ Warming Predictions #47
You walk to the nearest outlet and get a can of electricity.
Bruce
Sun shines electricity produced stored in battery one loss of energy conversion.
Now the gasoline fuel you talk about start the energy losses at the beginning. See how that works.
/ Warming Predictions #50
Of course I recognized it. I'm a bit of a car guy. You do have to admit that a lot of the hybrid vehicles wouldn't be sold if it wasn't for the huge tax credits. I did/do feel bad laughing at the situation. I don't wish a roadside failure on anybody. But it does raise an interesting point. If one has an all-electric vehicle (Isn't the Volt all electric?), how does one get it going if you run it entirely out of fuel? Are we going to have to have gas powered generators to be able to charge a stranded electric vehicle?
The idea of renewable becomes comical as you walk toward a gas station, even funnier if on a calm night. HS
/ Warming Predictions #51
They have these trucks with large beds on them that will carry the car to any destination.
/ Warming Predictions #52
The volt is electric powered to the wheels but has a gas motor to provide charge. The prius is a hybrid and the gas engine kicks in about 35mph and turns the transmission.
The volts gas motor will not run the wheels, only turns an alternator basically a generator but I believe you have to still charge it plugged in because the generator is only a sort of booster for mileage or like a spare tire. It gets you to a plug.
/ Warming Predictions #53
This is a common misunderstanding caused by some inaccurate statements from GM. The Volt engine actually does directly drive the wheels at higher speeds and when the battery is low. This makes sense because that's much more efficient and the Volt still doesn't have enough range to make the use of engine an unusual mode for most people.
https://www.cars.com/articles/2010/10/the-great-chevy-volt-hybrid-mishap-explained/
/ Warming Predictions #54
The idea of using gasoline for a constant normal commute becomes comical when the price of gas goes back up. Not everybody needs a 400 mile daily range.
/ Warming Predictions #55
/ Warming Predictions #56
What happened to the most powerful El Niño in history. I'm hearing it's gone! Who cooled the Pacific Ocean in a few months? HS
/ Warming Predictions #57
What I see on the weather stations El Nino is alive and well. We were 76 degrees yesterday and in the 70's today and tomorrow. Also way behind on snowfall this winter. That is typical for us in this area during El Nino. Spotted the Seagulls hovering overhead this week. They are starting their northern trek a little early.
However, we have only broken the high temp record on one day so far. It was warmer in the 1930's than now even with El Nino.
/ Warming Predictions #58
So, do I understand correctly that the way to get an all-electric car that is out of charge running again is to call a tow truck? Wow!?!? Running out of juice will cost $75 to $100 for a tow?! I'm pretty sure I will stick with internal combustion engines.
/ Warming Predictions #59
So, is it possible that there was even a stronger El Nino in the 30's than now???
/ Warming Predictions #60
From a recent article in the Wall Street Journal, I don't think we are going to be seeing any increase in power plants any time soon. The gist of the article was that the Sierra Club (and some other environmental org) thinks they have banned coal plants completely with the Clean Power regulations. Basically they are mandating controls so expensive that all coal plants will have to close over time. The prediction was that there will be power shortages as the plants go off-line.
For right now we might be okay as the Supreme Court has put a stay on the rules but if they are eventually allowed to go into effect, it sounds like there won't be enough electricity generated for our current usage let alone increased usage.
I'm not trying to offend anybody but the realistic view appears to be that the "environmentalists" are setting us up for a drastic change in lifestyles. In fact, that is the reason I am seriously considering some solar generation at home but I have a serious problem in that my house is orientated wrong for solar.
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
RING 2 STARTS HERE @ 9:15 AM (A62130)
RING 2 STARTS HERE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
1004 (A61166)
1004 (A61166)
