question regarding loader control valve on my g3033
   / question regarding loader control valve on my g3033 #1
bclark1953
kenduskeag maine
ls g3033
My ls g3033 loader has floppy bucket syndrome. Huh. So I believe that the dump/curl valve for the loader is just your standard hyd directional control valve as opposed to a (either 3 or 4 position) valve with regen feature. Does anyone know exactly what type of loader control valve comes with these tractors and if it doesn't have regen, if ls offers one with that feature. Also the loader is a Ll3102. Thanks
Thanks for the link. I did try all the other tractors on the dealers lot and they all do it. So I'm thinking that the thing just has a standard directional valve with no regen. But as someone who works with hydraulics I prefer a print of the valve schematic to verify that
   / question regarding loader control valve on my g3033 #4
Pretty simple to tell if regen, swap the hoses and see if it will curl back if yes not a regen spool. Since the bucket is floppy I suspect it is not a regen spool.
   / question regarding loader control valve on my g3033 #5
I do have the service manual but there doesn't seem to be anything in it about the loader control valve ---- or any part of the loader for that matter.
If you learn how to fix it, I would like to know.
As JJ mentioned in that thread that I referenced, there is a "fast" and a "slow" dump. If I strictly use slow dump, I don't seem to experience the problem. I certainly do see the problem if I use fast dump.
   / question regarding loader control valve on my g3033 #6
You should be able to tell by the two dumping speeds.
Maybe your valve has regen and you are not going into the regen mode.
Some valves have regen in the first part of the lever travel and others have it to the far right.
If you have regen, you might not be able to raise the front wheels off the ground, wheres with non regen you should be able to raise the front wheels off the ground.
Depends on the valve whether there is a kit to make the valve regen.
Here is a regen kit for a Kubota valve.
Kubota "La Series" Hydraulic Control Valve Detent Regen Kit 7553665100 | eBay
Prince has parts for a regen spool.
http://www.princehyd.com/Portals/0/valves/ValvesLvs.pdf
   / question regarding loader control valve on my g3033 #7
There have been a number of these "floppy bucket threads" in the LS forum. I don't recall any dealers contributing to those threads. You guys ought to know the most about this loader valve. Any help out there ------------?????????
   / question regarding loader control valve on my g3033 #8
I've never used anything but slow dump but my bucket still flops. If I hold the lever for 45 more seconds it will become rigid.
Eugene
   / question regarding loader control valve on my g3033 #9
Sounds like the system is sucking in air from somewhere.
   / question regarding loader control valve on my g3033 #10
On bucket control spools the pressure port should open to the blind end of the cylinder before the rod end port is opened to tank or what is called meter-out control. This is difficult to match the valve to the cylinders when the valve is used on multiple size cylinders.
If the rod end opens to tank the weight of the bucket will cause the cylinders to extend drawing a vacuum in the blind end of the cylinders. This vacuum is what creates the flop in you tilt cylinders. No external leaks are required for this vacuum to be created. That is why holding the valve open and keeping pressure applied in the dump mode reduces the flop.
A regenerative system usually reduces or prevents this since both work ports are tied common to the pressure port.
   / question regarding loader control valve on my g3033 #11
reduces the flop.
Also keeping the engine revs up, esp with tractors that have low implement pump flow rates.
Good post, O&S.
   / question regarding loader control valve on my g3033 #12
Good post, O&S.
I just picked up a new LS XR4145 and it is already doing this. My guess is that this loader valve is not setup as a regen (lame and cheap) for bucket dump and is sucking AIR in and cavitating. I order a Prince flow restrictor that I will put in on the return line of the curl cylinder so it forces the dump action to fill up and force the curl instead of letting gravity pull it down. My theory is that if i tune it just right, it will only slightly reduce curl up speed and take almost all of the slop out of the bucket.
Flow restrictor (adjustable)
3/8 NPT 8 GPM PRINCE WFC-600 IN-LINE FLOW CONTROL
   / question regarding loader control valve on my g3033 #13
If you get this set correctly it will help reduce the run-away tilt function.
   / question regarding loader control valve on my g3033 #14
Just got it setup. Definitely an improvement with no noticeable flop. Here is a picture. I didn't realize that the flow valve is free flow in the curl position so there is no impact on curl speed.... Bonus!
   / question regarding loader control valve on my g3033 #15
Thanks Joe ---- I'm buying one!! I've been looking for this for a couple of years now. What flow rate did you set on that valve??
   / question regarding loader control valve on my g3033 #16
Its hard to really say what the flow is set at. What I did was basically turn down the flow until the bucket dump slowed just a little bit and the tractor started to labor a little bit when dumping. Best of luck. I put another hour on it this weekend and its working great still.
   / question regarding loader control valve on my g3033 #17
Understood --- Thanks for the reply. USPS will deliver in the next week or so.
   / question regarding loader control valve on my g3033 #18
You will need a 3/8 male/male NPT nipple also if you didn't order it. Can also be had at your local farm supply store. I took the entire line off the tractor and set it up in a vice. I didn't think I could get the fittings tight while still mounted.
   / question regarding loader control valve on my g3033 #19
I installed mine today. Haven't really pushed it yet but looks encouraging. It does slow the dump speed as I guess I could have figured, but I think that's OK with me. The good news is that it's adjustable so, if I can't stand the slower dump speed, I can just open it up. That's with an empty bucket too. We'll have to see if it's still slower with a full bucket. All in all, pretty nice for $38.
   / question regarding loader control valve on my g3033 #20
Can you guys elaborate more on the bucket flop issue you are experiencing. Not sure I follow what you are describing. When exactly does this occur? I have an R4041 and haven't noticed anything unusual when I dump the bucket.
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2023 MORBARK WOOD HOG 6400XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2018 RoGator 1100C (A56438)
2018 RoGator 1100C...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
