   / Harbor Freight Tools that don't suck #5,301
Isn't that that a waste of old tin and used plywood?
They use it partly to camouflage the installation: during the 2011 ice storm that went through central MA. NH and CT, there were incidents of generators being stolen while people were away at work.
We have a longer cable so we can keep the generators behind a locked gate, and in our line of sight. Easier to refuel in bad weather as well.
   / Harbor Freight Tools that don't suck #5,302
   / Harbor Freight Tools that don't suck #5,303
I live at an intersection of a gravel road and 2 lane black top. The gravel road separates our house and barn, and the barn is where the generator is stored and used. Nice lean-to roof area to run the generator, but then it's fully visible to everyone. Yup, it gets chained up when it's out in use. And fully visible from my bedroom window and meny others from the house. And well within range of any handy firearm.
   / Harbor Freight Tools that don't suck #5,304
Price just went up but still a good deal. I had a coupon so paid $279 plus plywood.
1720 lb. Capacity 48 in. x 96 in. Super Duty Folding Trailer
The bearings come in a preservative. The directions are very clear that you must clean and repack the bearings, but some people don't. Took about 5 hours to build. I added a ground wire to the wiring harness and soldered all the connections. Coated the plywood with rubberized paint.
Nice. How do you load your snowmachine?
   / Harbor Freight Tools that don't suck #5,305
That's not my sled and I can't speak for the owner but I have loaded many that way. Only the first time is the issue because of no snow. After that, you load and unload on a snowbank. You can put them in the back of a pickup that way. Piece of cake.
Probably the first loading is to back the trailer tires into a ditch and that brings the bed close enough to the ground.
   / Harbor Freight Tools that don't suck #5,306
   / Harbor Freight Tools that don't suck #5,308
It tips (you can see the pins at front) so you can drive it right on.
That sled is a big girl: over 700 lbs wet. Handled great.
Thanks, I wondered if you tipped the trailer. Must take a light touch to stop the sled right at top dead center of the pivot point! :thumbsup:
   / Harbor Freight Tools that don't suck #5,309
I have a "quality" code reader for my vehicles. Found it was the cheapest way to deal with my wife not putting on the gas cap tight.
Well, last night my F150 threw an ABS code and of course my reader is not in this state. Wondering if I just purchase another "quality" reader or if something like this does the same job
OBD II & CAN Code Reader with Multilingual Menu
Kubota MX5400 (A57148)
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
