newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,816
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I think backhoes on midsized CUTs have more power than you give them credit for.Operating a tractor is more complicated than novices expect. A new tractor is easier to learn on. Most tractor novices do not realize that the Three Point Hitch is the key part of the tractor. You want to keep ithe 3-Pt. available for implements and not cover it with a Backhoe unless you will use the Backhoe a good deal. Backhoes on the size tractors you will be considering are not very powerful but they are expensive. A new tractor may be within your budget if you forgo a $5,000 to $7,000 Backhoe. [/SIZE]
Most have enough power to lift or drag the tractor around and can be removed/installed relatively quickly.
Takes me only a few minutes to remove my backhoe and maybe 5-10 to install.
A couple of points on this -
You are going to need a tractor of at least 30HP unless you are going to do things in a small way.
A backhoe with FRAME and thumb will probably run around $8,000 and up UNLESS you can find a used one.
IF you can drop your backhoe so you can EASILY move it (like on a dolly or on a crane) into position I expect a 5 minute install would be easy. My BH takes about 15 minutes to put on, 5 minutes to take off. That's still 20 minutes out of your workday, plus putting on and taking off 3 point implement.
But with a Quick hitch changing 3 point implements usually may only take a few minutes. I write usually because a stuck PTO release collar may take 5 minutes to loosen
