STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD?????
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #1
natasatan420
woodland, CA
stihl
IMG_20151218_085109.jpgMs 290 won't start, feels like low compression when I try to start.piston looks pretty bad. I got spark and fuel. Time to rebuild the Top-end???????IMG_20151218_085003.jpgPHOTO_20151218_041923.jpg
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #2
Bad is an understatement!!!!!!!!!!!!!!!!!
Maybe time to toss it.
OR: Stihl | Chainsawr
Here you might foind what is needed for that saw, if worth rebuilding.....
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #3
Looks like low oil mix. A rebuild should be pretty trouble free. Cheaper than replacement.
How old is the saw? I have a MS290. guess I better take a look at my piston/cylinder.
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #4
That is scored up pretty bad, looks like it was run on straight gas or maybe not enough oil.
The 290 isn't a great saw, so I wouldn't invest a lot into it unless it can be fixed on the cheap.
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #5
You can get a Meteor piston for $40 at Baileys, in your home town. They might be the biggest
purveyor of chainsaw-related stuff on the whole left coast.
Sometimes you can save the jug, if it is not gouged, but yours looks really bad. I would go for
an aftermarket piston/jug kit. You can get the whole cylinder kit for under $40 if you shop around.
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #6
Wow.. Nasty. Looks bad enough that there may be aluminum shavings crap in the crank bearings too. look closely..
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #7
Better yet, look closely as you toss it on the scrap heap. That saw is toast.
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #8
Really? That saw is easy to fix (as long as you do NOT take it to a Stihl dealer) and all the parts are
available, cheap. Easy to check the crank bearings, or put new ones in. I have had a couple of them.
A rebuilder will pay good money for that saw, as-is.
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #9
I respectfully disagree with that saw being worth good money as is. What do you think the rebuilder would toss for that saw, as is?
To me it's not worth it unless one devalues one's own time. Time is not as most refer to it: money. It is only time ~ and we have nothing else but it to spend. Money can buy lots of stuff, but not love, and not more time.
My time is worth more than rebuilding a whipped saw. I'd rather buy something already working and not beat up.
To each their own. To me time is my most valuable asset, bar none.
   / STHIL MS290 CHAINSAW TIME FOR A TOP-END REBUILD????? #10
I realize that most people do not have the ability and/or inclination to fix this saw. We live in a throw-away society,
so broken items are usually tossed in the scrap heap, as you say.
But let's not project. A rebuilder or DIY guy would pay $40-50 for the saw, buy $50 worth of parts, and sell it for
$300. Some of these guys are amazingly fast, and may put only an hour or 2 into the saw. That unit sells for
about $400-450 new. It is a Stihl, and they always sell for good money in any condition, in my experience.
As for myself, I do it for the enjoyment. Some folks do crossword puzzles; I like to rebuild/modify engines.
2002 MACK CHU613 BOBTAIL VAC TRUCK (INOPERABLE) (A55745)
2002 MACK CHU613...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2011 Chevrolet Malibu 2LT Sedan (A54815)
2011 Chevrolet...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
