I'm building a wood shed....I need some help
   / I'm building a wood shed....I need some help
Yes, I was thinking a string line with a level. And you're right, its just a wood shed doesn't have to absolutely perfect.
   / I'm building a wood shed....I need some help #12
Never heard of the 3,4,5 rule. I was thinking of doing the A squared x B squared = C squared.
12x12= 144
16x16= 256
____
400 squared = 20
Then measure 12' and 20' from two stakes until those two measurements cross and then that is my corners?
Unless the 3,4,5 rule is easier and someone wants to explain it
9+16=25. Same rule, you just multiplied by 4.
   / I'm building a wood shed....I need some help #13
Whenever I try it, I never seem to be able to get all the posts set to the same height. My thought is set your posts, hang your header level, then trim whichever post(s) is/are too tall. If you're running rafters and purlins, remember you don't have to cut the posts shorter than the header, just shorter than the top of the purlins, so you have at least a rafter's worth of leeway up and down. I like to run the posts a little tall and bolt the rafters to them too just on principle anyway...
   / I'm building a wood shed....I need some help #14
The easy way is to set some string lines using stakes outside of the building footprint. Then buy posts that are too long. Set the posts and use some 2x4's and stakes to brace them plumb in both directions. Now pour the concrete taking the time to check the posts for plumb. The next day come back and snap a line at the height you want the posts to be and then cut them off. Might waste 2' of wood, but it's cheaper than buying and setting a new post.
   / I'm building a wood shed....I need some help #15
12x12= 144
16x16= 256
____
400 squared = 20
(3x3) + (4x4) = (5x5)
Your building is just 4 times this size, so the diagonal is (4x5) = 20, just as you calculated.
   / I'm building a wood shed....I need some help #16
I think the method "Cord" described is the best. I just poured a 18'x24' monolithic slab and ran my stakes beyond the outer edges of the perimeter. This way you make your adjustments so the intersections of the strings are exactly at the dimensions you want. Best to just cut the tops of the posts once they're cemented in so everything is at the proper height to be level.
   / I'm building a wood shed....I need some help #17
12x12= 144
16x16= 256
____
400 squared = 20
You did a great job explaining it.
Cord's instructions may be the easiest for me to do. Problem is I already bought my posts. 12 and 10 footers. I may be able to return and exchange the 10 footers. Holes are already dug so unless I feel like back filling the holes to get my post height where I need it, I may just exchange them. And once I layout the area again with a string line, I know I will be shaving some holes because I rushed this and they may be off a little.
   / I'm building a wood shed....I need some help #19
yall totally lost me on that 3,4,5 rule? where are you measureing? diagnal from corners, or toward the other posts?
I would just measure diagonally between posts and then just make my posts taller or close to the height they need be and bolt my headers to them and if too talll cut off the excess. Thats how i made mine. I built a 12x16 woodshed and put it on 4, 4x4s but i put the posts like 8x12 or so and have roof overhanging where the posts are located a good bit to shorten the run of the header as i did not want a center post. We seldom have snow in this area so snow load is about a non existent problem although i did have 5+" of heavy wet snow up there a few years ago with no trouble. My shed is open on all sides though so that i could pull wood from different areas. If i were to do it again i would make three sides probably to keep blowing rain off, but it does help the drying process to not have sides even if you make gaps in the boards. And because i still have roof outside my posts i would have to get creative on how to make the sides now to not loose under roof area.
i think i may add onto one side about 6-8 foot and may make that new section sided when or if i do. But i bought a new metal carpost thats 18x21 for wood so that i dont think anytime soon i need a new addition to the old wood shed.
   / I'm building a wood shed....I need some help #20
3' on one side, 4' on the other side of thecorner. When they are 5 ' apart, it is square.
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
Unused Delta Crash...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
