Snow To fill or not to fill
   / To fill or not to fill #21
419;
You might check with your dealer, they can fill tires easily as they do it all the time. As far a fluids go, there is Rim Guard (beet juice) probably the most expensive. Then you can use RV anti-freeze (non-toxic) cut with water to whatever freeze point you need. Or you can use windshield washer fluid which is available in 55 gallon drums.
I would stay away from calcium chloride solution though. Here is S. Texas, where freezing is not an issue, we can use straight water or straight water with maybe 20-25% RV anti-freeze.
I have filled my own tires using a garden hose and the adapter that James mentioned. The adapter is about $10 at Tractor Supply.
I recommend filled tires over a weight box as nothing to hook up on tractor.
Good luck!
Sent from my iPad using TractorByNet
   / To fill or not to fill #22
Avatar, what the little rat rod?
   / To fill or not to fill #23
   / To fill or not to fill #24
So this one is built by a shop in Florida. El Chappa. Peterbilt road tractor 425 Cat and a 10 speed.
built a KW a while back 3 axle all wheel steer for a guy to haul his Grand Teton 5th wheel.
Started another KW similar to the Avatar but it has a long way to go. Front suspension moved way forward (3 ft) Engine and cab shift rear ward and hood stretched. Looking at a 50s stepside bed and refurbing a Cummins motor. Trans is a autoshift 10speed, which is pretty slow shifting compared to a jake brake and a hand shaker.
   / To fill or not to fill #25
Tire most like will not have to be filled. :)
   / To fill or not to fill #26
Picture this next build as a 34 Ford F1 on steroids with a stretched hood. To get more of a Rod look I am going to replace the front wheels with 19.5 vs the std 22.5s. And a set of 24.5 super singles out back. I the middle of building a new place and this project is on the back burner. Biggest issue is not the build but the size and weight of the components. The Cummins motor is a 600hp model with little under a million miles. I will have to fab a set of long 34style fenders and running boards a then figure out how to fender the rear tires.
I have a set of late 20 headlights 10 inch across that I want to use and not sure if the top will be chopped. Google El Choppahead and there are some insane U tube vid out there.
   / To fill or not to fill #27
Initial cost was cheap $5K for a running tractor.... now where it goes from here????$$$$
But I still do not recommend filling the tires on a SCUT.
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
2013 Ford Edge (A54815)
2013 Ford Edge...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
MISC TIRES (A54757)
MISC TIRES (A54757)
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
