Rotary Cutter looking for guesstimates for how long it would take to clear 2.5 acres of blackberry
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #1
dgarrett
Member
Kitsap WA
Kabota B2320 Narrow
Using a rotary cutter and backing into 6-7ft high solid blackberries. I have a Kubota B2320 so I cannot plow through and flatten them before they are cut with the rotary cutter. The cutter is 48" and will raise it up and back into the berries. I had two quotes, one for $3000 and one for $4200. Both quotes were 3 to 4 days of work. I figure if I were to use my tractor and rotary cutter it would take me 4 to 5 weekends to get it done and wanted to get your opinion on how long it would take me. Much appreciated in advance!
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #2
Well, I haven't seen your land or the berries, but I would put my guess at about 2 weekends. Maybe less.
Thanks. The land is flat and does not have any stumps, old cars or sheds. No big rocks either. It used to be a vineyard so the 60" row spacing trellising is still there and I want to keep it intact.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #4
We will see what some more experienced brush hoggers will say, but if you shred em for an hour or two you will soon know how it is going to go.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #5
If you have a FEL on your tractor consider adding a Ratchet Rake to your bucket. Nothing better for tearing out brush and Blackberries. Then, run over debris with your Bush Hog.
After you Bush Hog the Blackberries, consider pulling a Field Cultivator over the roots.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #6
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #7
Are you just mowing the middles in between the trellis rows?
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #8
I give up. Why cant you just go forward? It would save a lot of time. A 1400 pound 4wd tractor should roll right over blackberry bushes.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #9
Do you have pics of the area you want to cut, if you can post some that too would help us give you some info.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #10
Any pictures?
Year: 2008 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2008 Make...
FLOOR JACK (A55745)
FLOOR JACK (A55745)
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
1831 (A51247)
1831 (A51247)
