How many hours is too many? John deere 4520 utility
   / How many hours is too many? John deere 4520 utility #1
1937
mcGregor
NA
I'm looking at a John Deere 4520 utility with almost 2200 hours. It has been well maintained and in good condition. It has a loader with a factory cab and they want $25,500 for it. Is this too many hours? Are there big ticket repairs it would need after so many hours, or concerns with hydro repairs?
   / How many hours is too many? John deere 4520 utility #2
I just saw one on tractor house with 800 hours for $23,000
   / How many hours is too many? John deere 4520 utility #4
What does that have to do with hours? Great resource though.
The tractor would be used to maintain 14 acres and will be used for grading, bush hogging, snow removal, tree removal and general maintenance.
   / How many hours is too many? John deere 4520 utility #6
I have seen JD large frame 4000 series compacts with over 6000 hours. It is not so much the number of hours, but the kind of hours & how the tractor was cared for. I have seen tractors with a few hundred hours that looked like junk & tractors with a couple thousand hours that looked like they were new.
   / How many hours is too many? John deere 4520 utility #7
First, are you writing about the tractor shown in Boggen's link:
TractorData.com - information on all makes and models of tractors John Deere 4520 tractor information
or are you asking about the newer large CUT?
Can't write anything about the older Utility machine, since I have no experience with them. The newer 4520 has (up until 2014) a Deere Powertech engine....same one as used in the Deere skid-steers. This engine is supposed to be good for 8000 hours. The 2015 4520 CUT has a Yanmar engine...great engines! Not sure about the durability of all the tier 4 emissions crap though.
On a personal note, my 4520 CUT has 2100 hours....bought with 2075 hours on it, BTW. Runs strong and had definitely been used hard by the previous owner. But, simple machine with few extras that could break. I'd have no hesitation buying a CUT with a couple thousand hours on it.
   / How many hours is too many? John deere 4520 utility #8
The hours are less important than the maintenance and how it was used or abused.
My 2004 Suburban has over 2200 hours on it and you cannot tell it has been used.
I have a friend with a 1985 Kubota with over 20,000 hrs. It was used commercial for the first 15 years of its life and now mows 10 acres and maintains 900ft of gravel road.
Regular maintenance is the key factor in longevity.
Thank you for the information and yes I was referring to the the utility tractor. The tractor was owned by a golf course and used mainly for mowing.
   / How many hours is too many? John deere 4520 utility #10
Then 2200 hours is extremely low for it's age (at least 35 years since manufacture)...it sat a lot more then it worked. It really depends on how easily it starts and how well it runs.
I'd change all the fluids since the oil, antifreeze and hydraulic fluids probably haven't been changed in years. I'd also look for a ROPS and seat-belt.
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
