do you guys use fuel additive in winter ?
   / do you guys use fuel additive in winter ? #1
cvcman
syracuse ny
john deere
Wonder if my XJ2025 should have additive in the fuel this winter....most guys I talk to say you don't need it...
   / do you guys use fuel additive in winter ? #2
I don't use it very often. "Power Serve" occasionally. But, if I lived in NY I would use it regularly.
   / do you guys use fuel additive in winter ? #3
Since I have had to walk home a couple times and limped a few other occasions I always use an additive to prevent gelling.
I also filter while filling to strain out any water and or debris.
I use a very fine mesh filter and it always seems to catch anywhere from a drop to a tablespoon or two.
I also like to keep my fuel topped up to prevent condensation.
   / do you guys use fuel additive in winter ? #4
No, but my tractor sleeps in a garage heated to 45F.
   / do you guys use fuel additive in winter ? #5
Gotta be honest, a bit worried about this myself. Not sure I'll use it this winter though...we're not on the land yet.
   / do you guys use fuel additive in winter ? #6
Wanted to, started to, forgot to do it, remembered to do it again then forgot it again. Now I just forget it completely and everything runs just fine. I wouldn't unless troubles like gelling appear and they never have for me in 23 years.
   / do you guys use fuel additive in winter ? #8
Had my Dodge Cummins since 98, have never added anything to the fuel. Never had any problems either. That would include some high elevation very cold starts while snowmobiling here in Utah/Idaho/Wyoming.
My tractor was new the day after Christmas last year and I never put anything in it either.
Not to disagree with Piloon, but don't fill your tanks with diesel until the filling stations are completely changed over to winter grade diesel. I think sometimes people have full tanks of summer or transition fuel when it gets cold and then have problems.
   / do you guys use fuel additive in winter ? #9
This.^^^
If you use it, it probably doesn't matter; if you don't, power service and a battery maintainer.
   / do you guys use fuel additive in winter ? #10
Projecting TN weather related experiences to Upstate NY won't help the OP.
I use an anti-gel from October on. I've had fuel problems in winter before, they are no fun. If I can prevent trouble with a small investment and effort you can bet I will.
2014 CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52709)
2014 CATERPILLAR...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
Rome PT 7' Disc V-Plow (A57149)
Rome PT 7' Disc...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
206320 (A57192)
206320 (A57192)
