Front receiver hitch on F-150
   / Front receiver hitch on F-150 #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
I plan to add a front receiver hitch to my pickup. I found one from CURT that does not satisfy me. It's too low, and too far under the bumper. For me it would be always full of dirt. I sure as heck wouldn't drive with a receiver-mounted winch in the CURT unit.
I used photoshop and put the receiver where I want it, except about 8 inches off center. Pretty sure I can get structure to the frame.
This pic is from the CURT website, but I photoshopped another receiver higher where I want it (equal to height of the REAR receiver).
434908d1438319387-front-receiver-hitch-f-150-a-f150-curt-front-hitch_mod-jpg
I mocked up the structure behind the bumper with 2" x 2" cedar. Not sure how I'd get it in there if it was welded, I think it has to bolt together.
434910d1438320657-front-receiver-hitch-f-150-a-f150front_hitch_mockup-jpg
Has anybody seen a good way to do this on an F-150? Any other comments about front-mounted receivers?
   / Front receiver hitch on F-150 #2
Ranch Hand has a replacement bumper with a trailer hitch in the center of it.
>>>The Summit Series Front Bumper Replacement still provides superior protection similar to the Legend while offering an alternative style with reduced weight.
This bumper is designed and ideal for half ton trucks. It is frame-mounted and is one-piece fully welded construction. The main body of the bumper is manufactured from diamond plate steel and the grille guard portion provides wraparound headlight protection. The punched plate grille insert is specifically designed to match the make and model of the vehicle – no expanded metal used. Most pre-2014 Summit Series Replacement Bumpers allow for the optional patented H2R (Hidden 2" Receiver). In some applications, factory fog lights and tow hooks can be retained.<<<<<
Summit Front Bumper - Quality Ranch Hand Product
Hmmm never thought of that. Seeing them I don't think I want to change the look of the truck that much, just want a receiver. Plus I bet it's $600-800. I think I can build this in a half a day, just gotta get a good plan.
   / Front receiver hitch on F-150 #4
I built one for a customer about a year ago for his '14 F150 with the 5.0L . It came out where you want but centered, I should have the dimensions and pictures somewhere at the shop.
It was one piece and could be installed with only minor removal of some plastics and sandwiched between the tow hooks.
   / Front receiver hitch on F-150 #5
I had one on a 1961 4wd Chevy. Very slick for parking boat trailers. Mounting it offset to the left (driver side) gives you better perspective on both rear corners of the trailer as you are pushing it back.
   / Front receiver hitch on F-150 #6
I had one fabbed for my 2007 Jeep Commander. I used it for my winch. I made a winch cradle that also had a 2" receiver. So I could connect a trailer when using the winch. Then I could winch stuff up onto the trailer.
I now have a 2014 F150 and have been considering a front receiver for it.
GP I would do the same but have a 2" receiver on my trailer for that.
TMGT I'd like to see pics. My current desire is that its kinda 'hidden'. I don't really like the 8" off center but dont think it makes much difference.
Pat I would have chosen the driverside hole for my wooden mockup but the R side hole is blocked (steel) which I can cut out.
Thanks all you guys for feedback. I bought 2x2x3/16 for the structure, thats about where I'm at so far.
   / Front receiver hitch on F-150 #8
I haven't looked closely at that area of my truck but looking at your pictures, I think I would make up some plate to bolt to the inside of the frame rails and then weld the cross piece of 2 inch tube to those plates then bolt it to the frame rails. If a one piece receiver can't be made to go in place, then weld some plate in the middle of the cross piece to bolt the 2 inch receiver piece at a 90 degree angle.
Just thinking out loud here.
GP that's in general what I will do. Trying to think of a way to use existing holes on frame rails,& not welding on the frame. Probably will use the towhook bolts on the frame bottom but they won't be sufficient. Getting some support at top of the frame will be necessary but haven't decided how yet. I might drill the frame though. May have to build "nut-holders" to extend to access existing holes.
   / Front receiver hitch on F-150 #10
I just went out and looked
My bumper is a little different so I could have the receiver centered. Anyway it looks like you could make 2 "L" shaped brackets, attach to the bottom of the frame rails where the tow hooks are and run the other leg of the L up the inside of the frame rail. Drill for bolts through the side of the frame rail.
You could bolt the tow hooks right back on, sandwich in the bottom of the L bracket between the hooks and frame rail, as mentioned by TMGT.
I haven't determined yet whether or not a complete one piece receiver can be put into position to be bolted on the rails. May have to have the actual receiver portion bolted as previously mentioned.
I probably won't do mine until fall.
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
