Branson 3510i hydraulic problems
/ Branson 3510i hydraulic problems #1
btsavage
Wales, MA
Branson 3510i
I have a 3510i that has developed a hydraulic problem. The whole system has weakened drastically over the last few hours of use. Right now if it's not at least at 2200 rpm, it will not raise the empty loader bucket. The backhoe (Branson 7620) moves very slowly and again not at all at low rpm. I tried changing the hyd filter (OEM filter) and topping off the fluid but it did not help.
I'm in the middle of a project and need to get back up and running. Any advice appreciated!
/ Branson 3510i hydraulic problems #2
The pump flow is escaping at a low pressure some where. This could be due to a relief valve stuck open. Does any part of the system seem to get hot faster? Do hear any sounds like fluid spraying, or squealing sound any where in he rear end?
Did you notice any change in noise when the system started slowing down?
I did notice a whining noise when operating the loader. I also noticed the loader valve is hot. i wasn't sure if that was normal. Also. Something I did notice is that rolling the bucket seems a lot faster than the lift. Is there s relief valve on the loader valves? Is there a way to isolate it and determine if that is the problem?
/ Branson 3510i hydraulic problems #4
If your loader valve has regen, the bucket will be much faster because you pump flow plus the other side of the cyl flow.
Your bucket curl up speed should be normal.
Whining noise sounds like relief valve, but that only comes on when you exceed the set relief pressure and that pressure is caused by load.
Ok, I think I was barking up the wrong tree. I noticed that the loader control valve is "sticking" and it got stuck in the float position. Took a pretty good whack on the control lever to get it out of the float position.
I'm now thinking that I have no pressure because the loader control valve is bad??
Anyone have experience rebuilding one of these? Source for parts?
/ Branson 3510i hydraulic problems #6
Install a $30, LF hyd gauge 3000 to 5000 psi test unit, and check the pressure .
Install the gauge in a tee in the IN port of the loader valve.
I just talked to the Branson dealer and he suggested the same thing. I've made some calls to NAPA and such and can't find a gauge locally. I really need to get this thing back to work.
I have a backhoe on the tractor and it's operating, but very slowly and no pressure. It operates off the hydraulic rear remote. Am I correct in thinking that if it's a problem with the loader control valve that the backhoe should still operate normally? I guess that I'm not sure how it works.
/ Branson 3510i hydraulic problems #8
I believe your tractor has a open center hyd system, and therefore the pump flow is flowing through all valves in series.
The pump volume is dictated by your engine speed.
So if your tractor is running full rpm, you should be pumping max pump flow.
A hyd valve controls how much flow goes into a cyl, so if you have full lever, the full pump flow should go into the cy.
Pressure is something else, and the pressure is developed by the cyl trying to do work by the load imposed on it.
A bad relief valve can divert the flow.
A weak pump will not pump expected flow, and if no hyd, the pump shaft could be sheared off.
Have you checked for flow by removing a hose?
No, I have not removed a hose to check for flow. Also, at idle, the hydraulics will not move. I have to have about 2000 RPM to get the loader to move at all.
/ Branson 3510i hydraulic problems #10
Some of your flow may be diverted to the steering circuit using a priority valve, and you have to have more rpm for the hyd to work.
Say you had 10 GPM, and the steering required about 3 GPM. If your system does work by a priority valve, the steering will get the first 3 GPM, and if your engine rpm is low, that maybe all the pump is pumping.
Run the engine at max and see if the hyd improve.
When I run the hydraulics at max RPM there is some improvement but not nearly enough to work the tractor. For example, at idle, the loader will not move. At max rpm, it moves the full range empty, but will not move with a light load (manure) in the bucket. The dealer is leaning toward a bad pump. I ordered a gauge to install inline on the output of the pump, but it won't be here until tomorrow.
If it is a pump, has anyone had any experience using an aftermarket pump, such as those sold at surpluscenter.com ?
/ Branson 3510i hydraulic problems #12
Did you remove and clean the relief valve?
If you want to isolate the loader valve, take the loader IN QD and plug it into the loader PB QD, and this will bypass the loader valve and then if the BH works, the pump is good.
If still no or little flow, you can check pump flow into a bucket.
If the pump can pump 1 gal in 6 sec, you have at least a 10 gal pump.
I got the pressure gauge today and picked up the wrong adapter so I couldn't check it. However I pulled out the relief valve and checked it out. Not much there. A spring and a flat washer type thing at the bottom? It looked clean. Could the spring be weak?
I had the hose coming into the loader control valve off. I cranked it over and got a solid stream of hydraulic fluid over my head and the rops.
I put it back together and ran it for about two minutes. Same symptoms. However I did notice that the pump was hot. There is a second pump for power steering mounted in front of the pump that was cold to the touch.
/ Branson 3510i hydraulic problems #14
What you describe does not sound like a relief valve, more like a load check.
A relief valve is going to have an adjusting nut, springs and o-rings, or some small flat washes to adjust pressure.
You appear to have pump volume.
Does any hyd valve work?
Just got off the phone with the Branson dealer. They are telling me that they think it is the hydraulic pump and/or the drive gear. Apparently this is a big job and half the engine has to come apart. Anyone else ever deal with this?
/ Branson 3510i hydraulic problems #17
Where is the pump that you have to pull half of the tractor apart?
/ Branson 3510i hydraulic problems #18
You never said if the 3pt works normal.
The 3ph seems to work but I have the arms off for the backhoe frame right now. The pump is easy to get to on the side of the engine. Branson dealer thinks it's the drive gear which runs off the timing gear and powers both pumps. That gear replacement they tell me requires the front of the engine to come apart
/ Branson 3510i hydraulic problems #20
Thats right if the drive gear is broke.
