Ballast BX25 Capabilities
/ BX25 Capabilities #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
Looks like I may be getting a BX25. I have quite the to do list for it already. Wondering how capable it will be of a few things on the list.
I'm looking to get a 4 foot rotary mower for it mainly for clearing trails and fence lines of willows. How well will they work together?
Also I would like to run my Danuser MD-6 post pounder with it and would like to upgrade to a hydraulic top link. Would it handle the pounder well and is it set up for hydraulic top link?
Last I am wondering if the tires are able to be ballasted and if they are big enough to even worry about ballasting? I want to use it for pulling out small pine trees from a few clearings. IMG_4419.jpgIMG_3739.jpgThanks
/ BX25 Capabilities #2
This is Kubota's equivalent of JD's 1025R; I think. The 1025 can run a 4' bush hog very well.
I've drilled post holes with a 2 man post hole digger. It'll certainly do a lot better than that tool, which wasn't too bad.
I'd have the dealer ballast the rear tires. Cannot have too much ballast if you plan to have a loader on it.
Ralph
/ BX25 Capabilities #3
Even though the BX-25 is a little pit bull, you have to be careful if you go off-roading or into the brush. There is a plastic fan up over the rear axle that cools the tranny. It's a magnet for sticks. So you might want to invest in some under body armor for it. Some sponsors on this site sell it. Also the owner's manual recommends against filling the rear tires if you run a back hoe. I'm here to say that I drove my BX over the roads for 5 miles with the loaded tires and the hoe. I didn't experience any problems. Just passing on the info.
Good luck with the new tractor.
/ BX25 Capabilities #5
What did your dealer say when you asked him these questions? Did you buy the tractor already??
/ BX25 Capabilities #6
Your used to a "real" tractor... The BX is a heavy duty garden tractor (queue the guys saying Im wrong:rolleyes:) . It has low ground clearance and a very soft and unprotected underbelly for woods work. I dont know if your post pounder will work either. What Cat is it, what's it weigh? BX is a small Cat1/Cat0. It doesnt have a lot of 3pt lift, certainly not as much as your current tractor. A BX will handle a 4' BH, but I wouldnt go over 2" with it, some guys on here say you can cut 3"+ with a HD BH. You likely wont be popping trees out with a BX loader (maybe small stuff, but nothing over a few inches with any amount of roots, it maxes out at about 500lbs lift capacity)!
If you want something smaller, Id consider a B over a BX. Actually I likely wouldnt go smaller than an L if I was doing it all over.
You might be in for a shock going from an old school 70hp, heavy, ag tractor.
/ BX25 Capabilities #8
My experience and my recommendation too.
/ BX25 Capabilities #9
The little BX (and comparable from other manufacturers) are indeed "little bulldogs", but they are not made for clearing trees. It would be more maneuverable than your 3020 but lacks the weight and ground clearance for that kind of work. Pulling trees is rough duty and that hydraulic post pounder you've got needs to be on a decent sized tractor. Go up at least one size to get more ground clearance, but for the work you describe, I'd be looking for something closer in size to that old 3020.
/ BX25 Capabilities #10
The BX has a backhoe. It will do well on small stumps and trees. May take you a little longer, but can get the work done. As an example, my brother took his BX25 to our dad's house and we used it to dig out his old sewer line and replace it last Saturday. We dug a 75' trench about 3 feet wide and averaged about 4.5' deep the entire length in about 6 hours. While a bigger machine could have dug this much faster, we were still able to do it and was much better than using shovels. He has been digging out a lot of stumps at his property recently too. It may be small, but it certainly is effective.
I used it to fill some stuff back in the same day at dad's house. Having been used to the L3800, yes, it does lack some weight from what you're used to, but it was still very effective. The loader and bucket are lighter so it won't smooth as much in float mode on backdragging, but will still get you close. you just have to have a little more finess.
I have been very impressed with what his tractor will do. So much so, that my next tractor will be a BX2370. I will get the added advantage that I can mow with it to, making it more utilitarian for me. I will put more hours on it than I did on my L3800. Don't get me wrong, I loved the L3800, but just wasn't using it enough for my $ worth. If I was rich, I'd have both, and maybe add an MX.
/ BX25 Capabilities #11
Yeah..there is no way the BX will work with the post-pounder. It will spend most of the time up in the air on a post. These things are light weight compared to what you are used to.
I love my BX-25 but it is limited in many respects.
/ BX25 Capabilities #12
Without making a recommendation on whether a BX25 will work for what you've outlined, I can address the hydraulic top link question for you. I have one for my BX25, but I had to go aftermarket to add a dual spool valve to work the HTL. Kubota does make a dual rear remote kit for their BX line, but it does not fit the BX25 model, unfortunately. The Kubota valve mounts to the side of the HST but won't fit on a BX25 due to interference with the backhoe subframe. But, like I said, it can be done, but only with an aftermarket set up.
/ BX25 Capabilities
The post pounder is cat 1 and about 600lbs. It needs zero 3pt lift. Runs off pto only. All I need is easy adjustment of all three links
/ BX25 Capabilities
Well guys, I did it! I had the tractor on a extended test drive, pounded about 100 posts, dug some trench for my new chicken fence, did a lot of harrowing, and of course all the odds and ends around the farm. This tractor is awesome! Little upset I never had the time to try the tiller and snowblower. Unfortunately it wasn't quite the right fit for the price tag on it.aMG_5713.jpg
/ BX25 Capabilities #16
I think this is the first picture I've seen of a BX with post pounder... 100 posts in so it must have worked ok
/ BX25 Capabilities #17
How about more information on your post pounder, your soil and moisture when installing posts, and specifics on the posts you installed?
/ BX25 Capabilities #18
Well guys, I did it! I had the tractor on a extended test drive, pounded about 100 posts, dug some trench for my new chicken fence, did a lot of harrowing, and of course all the odds and ends around the farm. This tractor is awesome! Little upset I never had the time to try the tiller and snowblower. Unfortunately it wasn't quite the right fit for the price tag on it.View attachment 430167
Good for you ! Glad it works and you didn't get side tracked by a few naysayers about the cooling fan......it is a simple fix if you use yours in the bush , just hang a cut piece of plywood from the frame with some plumbing strap and you will be able to protect that plastic fan ........... the BX is a mini brute ! I made ATV trails thru my bush with my BX2660 (no backhoe just the FEL) and worked great.
/ BX25 Capabilities #19
I would love to see the size post this thing can pound. Any shots of your fence. I just remember the guy that put in my fence and he had a monster tractor and it was dancing around some.
Glad it has worked out well. Enjoy your little beast.
/ BX25 Capabilities
Post pounder is a Danuser MD-6. It uses pto to turn a rubber wheel. Use a lever to push wheel against the weight to lift it up. Lever uses brake pads to hold it up and release both pads and wheel to let it drop. Comes down with gravity alone so hitting power doesn't change with size of tractor. Ground is all clay soft to medium spring conditions
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
(2) 380/85R30 TIRES W/ 8 LUG RIMS (A64280)
(2) 380/85R30...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
2022 EZ-GO ELITE...
2025 Wolverine MSG-11-44W 44in Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
