Alien Invasion - I want my pond back !
   / Alien Invasion - I want my pond back ! #261
Yep time for the aquatic herbicide!! and you dont have fish so thats good!
Some aquatic glyphosate can take care of that above water stuff and possibly may kill underwater portions as its all connected but i would proably go stronger!!
Reminds me of our Hydrilla!!!
"everyone else calls it Australian stonecrop"
It wasn't ME! I haven't been to the UK since '91 at the Racal College in Heckfield (yes, that's it's actual name), between Reading & Bassingstoke.
It wasn't me who brought it over, I was last in the UK in 2010 and I never went any where Shropshire.
It's ok, neither of you need an alibi, Crassula made it to these shores well before your time. It is on sale in the "Perry's Hardy Plant Farm" catalogue - 1927 edition.
Autumn 2014 - How to evect an alien
I read lots of official recommendations on how to bring death to Crassula.
All of them say it is only a temporary measure - it will come back.
The good news is that there is a very effective chemical control.
The bad news is that the chemical was thought to be too good at killing humans too, so they banned it from sale a few years ago.
As clemsonfor said, a form of aquatic glyphosate can be used.
Using pesticides on water is strictly regulated and if I were to go through the official channels I would have a lot of red tape, plus that would be another magnet for bureaucrats coming round checking on me. I would also have to go and sit an expensive exam before I was deemed competent to do it myself. Alternatively, I could bring someone in, but with glyphosate it is highly likely that it only kills the part above the surface, they would have to keep coming back to get the shoots that then grow up from the stuff lurking beneath the surface.
On small ponds Crassula has been killed off by covering in black plastic sheet for 6 months.
Doesn't seem a feasible solution on a pond this size, although there is a variant on this which I will come back to later.
Not an officially recognised method. It was suggested by a friend who enjoys such spectacles and it could even work. Set a charge, or charges, underneath the alien and blow the whole mass outwards onto the bankside. It would be interesting to give this a go. Pity there is a public road running alongside one bank ...
Drain and dig it out
As much as I enjoyed the siphon, I don't plan on emptying this pond again, or this thread could turn into a groundhog day.
Nope, I promised I wouldn't go there.
The Institute of Hydrology warns not to attempt to remove Crassula "by mechanical extraction", otherwise it will grow again from the broken shoots. As much as I repect that the boffins in this revered institution know the biology of this plant, they underestimate the sheer satisfaction it would give me to physically evict the alien and pile it high on the bankside. They haven't come up with any good viable alternative, so despite the warning, dragging it out is what I will try and I will then do my best to find ways to stop it coming back. More on this tomorrow
   / Alien Invasion - I want my pond back ! #264
You did say that the pond resides next to a public road, right? It is not uncommon for things to fall off such public conveyances, even some as large as trucks, even from trucks that may be carrying aquatic herbicides. And if such a truck lost such a container on such a road and it happened to roll into your pond before it broke open, without a traffic camera there would be no record of the truck to trace the chemical back to its rightful owner... :eek:
Pull it out
With a piece of pipe and 10mm diameter steel rods, I made a grappling hook, expecting this to easily pull in a little bit of weed. First problem was getting a purchase. If I simply threw the grapple up into the air, it would land with an impressive splash but could not penetrate the mass of green below.
attachment.php
[Picture above was taken more recently with a mark 2 version grapple. You can see a steel rod sticking out above the surface as it rests on the weed]
Wading out with a spade I made a hole through the Crassula and dropped the grappling hook in, then returned to the bank and pulled on the rope. The green matt came to the surface and stayed there. No way could I get it to move. Another defeat.
Next try was with a much heavier rope, fastened to the Subaru tow bar. A steady pull and the grappling hook came to the bank with only a small clump of Crassula. It had bent back the 10mm grapnel rods. I repeated this a few times and each time I got a good purchase a rod would bend.
The alien had won again.
attachment.php
The mark 2 grapnel was made with 12mm rods and these did not bend. Finally I pulled a clump of Crassula to the bankside, however the clump was no larger than would fit in a wheelbarrow. With my wife driving we repeated this a few times. It wasn't a complete failure, but it certainly wasn't a success either. An hour later and we hadn't made any significant progress.
Over the next few days I tried all sorts of hook type devices to try and extract more with each pull. All were either ineffective or too slow.
attachment.php
At that point I changed tactics and looked for a way to cut the mass of Crassula into smaller, managable pieces that could be easily handled.
Neither shears nor hand saw were effective.
A long handled knife did cut.
My hand sickle cut really well, so I took the blade off and fastened it to a longer handle.
attachment.php
Finally I was getting somewhere. As long as I kept the edge sharp, I found I could cut the Crassula into strips and then tow them back to the bank. The days were getting shorter, however I was making steady progress, cutting for an hour or so every day. It was a good excuse to go play in the water and was very satisfying to see the green mounds around the bank grow ever higher.
attachment.php
   / Alien Invasion - I want my pond back ! #266
Holy Cow, that's a heap of vegetation.
Must be good for something. Compress it into bricks, dry it, feed the wood stove. Stall bedding? Compost? :)
   / Alien Invasion - I want my pond back ! #267
At this point, I would have called back the bureaucrat and told him he must've brought you this scourge on his mucked up boots. Pin it on him and take them to court. :)
   / Alien Invasion - I want my pond back ! #268
You, Sir Eric, are what in Texas we call "hardheaded!" Meaning, you start on a project and continue until you "get 'er done!"
You know, kinda like The Alamo, then Goliad, then San Jacinto! I predict that you will be victorious in the end...but it may take a while since we are still getting a history lesson. Surely, you would not have started the thread unless there is a happy ending to this delightful tale!
Autumn 2014 - Out on a limb
I had cleared a lot of weed out from the shallower water, where it was easy to wade. With chest waders I wouldn't be able to get to the centre of the pond and keep dry, though keeping dry was the least of my concerns. I didn't trust this stuff and having a large matt close around my chest as the wind changed direction made me even more cautious, I didn't want to provide cover for the local newspaper who would no doubt be overjoyed to run a "Drowned by an Alien" headline.
The plan was to cut a strip all the way around the edge of the pond so the weed was no longer anchored back to the shoreline. Once it was free I would find a way to drag the entire mass over to shallower water.
So I set to cut my way right around the perimeter. By this time I had done so much weed cutting that my wrist joints were aching, I could do no more than an hour at a time. At first the weed would bind on the sides of the blade as I tried to cut. Once the cut opened a little, I would wedge my knees in either side of the cut, just enough to ease off the sideways pressure of weed against the blade and gradually work my way around. Once the cut was a yard in length, I would make another parallel cut about a foot further out, then slice it off into a yard long strip. Each strip was raised for the water to drain, then tossed over onto the bank.
It was slow going, but eventually I had a foot wide strip all the way around the top side and around the far bank by the roadside.
attachment.php
Here an old oak tree had a branch growing out into the water, so I started to cut around this too.
attachment.php
[This picture taken June 2015]
Cut a strip, lift, drain, then throw to bank, cut a strip, lift, drain etc. Repetitive work, but it was a lovely evening for the time of year and I was very satisfied with the progress, although here there was still a fair bit of mud, I had to wriggle myself free of it before taking each step away from the bankside and towards the end of the branch. With the last strip cut, I dragged it back to the shore and tossed it up on the bank. It was very pleasant weather, warm, calm and very quiet. Not anymore though, that last strip of weed and possibly one or two before it had landed on a hole in the bank. I heard the buzz first and looked up to see dozens of angry wasps streaming out.
They were looking for someone to blame for the mess that had landed on their home and if I didn't move quick, they would soon figure out that was me. The only way to shore was to wade back through the strip I had just cut, right past their nest, so instead I headed back out a far as possible back along the branch. By the time I made it to the end of the branch I was in deep water, only just below the level of my chest waders. It took quite a while for the wasps to calm down and all the time I had to push up on the branch to stop me sinking further down into the mud.
Eventually I waded back around the pond and when I got back on the bank I could see the funny side of things. As wasps tend to make a new home in a different place each year, I decided to leave them well alone and come back to finish the job the following year. wasp1.png
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2009 Utility Trailer Mfr. 4000DX 53ft. T/A Dry Van Trailer (A56858)
2009 Utility...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2014 JCB 930 (A57148)
2172 (A58376)
2172 (A58376)
