Injury - Crushed finger in implement u-joint
   / Injury - Crushed finger in implement u-joint #1
greenmojo
Gold Member
Badger Mountain, WA
John Deere 4300, John Deere 450C
3 weeks ago, while building the pasture for the flying cow (different thread)...
I wanted to get the auger hooked up the night before starting work on it, so I could begin drilling post holes early in the morning. I was in a rush and it was getting dark. Dumb, dumb.
The PTO shaft was not yet hooked up to the tractor, and it was a bit dirty / rusty from sitting all winter / spring.I picked up the yet a few times to drop it and knock the dirt out of it, and finally I lifted up as hard as I could to throw it back down, and didn't realize that my finger had slipped up inside the u-joint. I felt it pinch, then the u-joint rotated, and the auger tipped toward me to rest against the three-point, and that was enough pressure that I literally heard a crunch so loud, it sounded like I bit into a carrot.
I dropped it, pulled my finger out and it initially felt like a good smashed finger. I pulled my glove off, and immediately noticed it wasn't straight, so I straightened it.
I knew it was broke, but wasn't sure how bad, so I went inside, iced it, wrapped it and took some ibuprofen.
The next morning, I have a dentist friend who was curious how bad I broke it and let me put my finger up on his X-ray machine...
Turns out I crushed it into more than 8 pieces... It's slowing me down.
Nice little lesson in taking things slow.
~Moses
   / Injury - Crushed finger in implement u-joint #2
ouch!
   / Injury - Crushed finger in implement u-joint #3
I've smashed some fingers, learned about gloves too. None of that would have helped you.
Does it feel better now?
It's healing up, but still a bit sore. Another couple of weeks and then I get to choose when they will re-break it to set pins.
~Moses
   / Injury - Crushed finger in implement u-joint #5
~Moses
Does this make you feel any better? Brush hog 3 point collapsed on my right thumb.
   / Injury - Crushed finger in implement u-joint #6
Very sorry.
You are right, bad things seem to always happen when you are tired, its late in the day and you are in a rush to get finished. We all know that in our brain but we still do foolish stuff.
Hope it gets better as fast as possible.
MoKelly
   / Injury - Crushed finger in implement u-joint #7
Sounds like something that would normally happen to me!
It always amazes me how fragile the body actually is.
Where does Holleywood find all these guys that are indestructable?
   / Injury - Crushed finger in implement u-joint #8
you run a farm and your hands and nails are THAT clean?
I'm calling shenanigans. :) :)
   / Injury - Crushed finger in implement u-joint #9
That thing is ugly (not your finger, don't care about that) the U joint and the coupler and from what I can see the slip splines. Own a grease gun? I suggest you use it before and after you put your digger away for the winter..........
   / Injury - Crushed finger in implement u-joint #10
I do not like hooking my auger up for the fear that I will end up doing something like you did.
All I cans say is that there is a reason most construction equipment does not use a 3 point hitch or a PTO like they do on tractors. I do not look forward to hooking up the auger at all as it is always a PITA it seems.
If I ever do it over I will buy a hydraulic unit for the FEL. Much easier to hook up, more down pressure, and you can even reverse it if you get stuck.
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
