What tool do you find most useful on the farm for general use (besides tractor)?
   / What tool do you find most useful on the farm for general use (besides tractor)? #1
Yamaha2112
CT
Various Diesel
My vote is this:
Cotter pin puller.
I've used it on more stuff than I can count.
Always end up grabbing it when I need to get creative.
   / What tool do you find most useful on the farm for general use (besides tractor)? #2
My vote would be welder and cutting torch.
   / What tool do you find most useful on the farm for general use (besides tractor)? #3
Craftsman 230A stick welder & Esab 625i plasma cutter.
   / What tool do you find most useful on the farm for general use (besides tractor)? #4
For me the "most useful" would hands down be a flat (nail/pry) bar...other than having the ability of gripping something like pliers or an adjustable wrench...a good quality "flat bar" will improvise for an array of common hand tools that are not always handy...i.e., hammer, screwdriver, nail,staple puller, scraper, roofing tool, putty knife, chisel, lever, wedge, etc...etc...they also make great digging/gardening tools...!
   / What tool do you find most useful on the farm for general use (besides tractor)? #5
Good thread, I'm looking forward to the responses. We grow vegetables and use lots of equipment in our production. Having the right tool close at hand is crucial to getting things done on time for us.
Welders are handy, of course, and i sure like my air impact gun, but they aren't easily brought into the field. I'm always trying to find the balance of carrying the right tools and not being weighed down. Right now I'm carrying a pair of slip-joint pliers and a putty knife. The putty knife is kinda hard to describe, though. I found it in my grandfather's toolbox and it's worn in just right. The corners are rounded and the edges are pretty sharp. It's great for scraping the crud off what I'm trying to work on and for cutting/clearing grass that's wrapped around tillers or mowers. Handier than I would have guessed and real light in my pocket. Also, I try to keep my dewalt impact driver close at hand. I'm on the lookout for a set of 3/8 impact sockets to keep right with it so I'm not running to the shop as often, but boy that's a handy tool also.
   / What tool do you find most useful on the farm for general use (besides tractor)? #6
A Crescent wrench. Works quite well for a number of things and fair to middling for a few other things. Hammer, measurement tool for small things, sheet metal bender, prybar, wire cutter if you have a sharp edge to use as an anvil. Attach a line to it and it becomes a Plumb bob, a weight for throwing a line up over a high branch when pulling on a tree, and for measuring depths of bodies of water and wells. It can be used as either an offensive or defensive weapon. It can be used as an impromptu volt meter to see if your battery still has a charge and if it does it can also be used as an 12V resistance type hand warmer. Drive it into the ground and you can use it to see if the hired man is actually moving. Of course when you run out of practical applications for it, it can also be used as an adjustable wrench for both right and left hand SAE and metric threads.
   / What tool do you find most useful on the farm for general use (besides tractor)? #7
LOL! Change my vote to crescent wrench!
   / What tool do you find most useful on the farm for general use (besides tractor)? #8
My constant companion is a Leatherman Wave in a handy pouch, with velcro flap, on my belt. Pliers, knife, serrated blade knife, screwdrivers, saw, file, scissors, bottle and can opener. Usually saves having to go and get a tool.
   / What tool do you find most useful on the farm for general use (besides tractor)? #10
My ATV with a small dump box on it. Takes me anywhere on the farm quickly, carries tools, saws, shovels, sprayers, and on and on.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
Aer Way Tillage Tool (A50514)
Aer Way Tillage...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
10 Ft Fork extensions (A50322)
10 Ft Fork...
