Blown engine; rebuild or replace with new
/ Blown engine; rebuild or replace with new #1
apctjb
Underwood, WA
Bobcat CT230
I have a JD LX255 which has a Kohler CV15S; 15HP single cylinder engine; turns over but no compression and a clunking noise so suspect thrown rod or piston.
Reading online it appears not an easy repair so wondering if purchasing a replacement engine might be a better option in terms of time and cost.
Would appreciate hearing from others that have had similar problems.
Any recommendations as to a good source to purchase a replacement engine?
I don't think the CV15S is current model so any recommendations as to current model Kohler that would be a direct replacement without a lot of modification.
Thanks
/ Blown engine; rebuild or replace with new #3
Get me the spec number so I know exactly what engine you have, and a possible conversion.
/ Blown engine; rebuild or replace with new #4
Replace it with a new engine. Call Small engine wearhouse they will help you.
Engines
Thanks for the replies.
Kyle in Tex; Yes the 26HP looks great; its has a larger diameter shaft so not a perfect fit. Would be nice however...
RandyT; The spec is CV15S-41571
JKR; Thanks
/ Blown engine; rebuild or replace with new #6
It looks like the entire command single line has been replaced with the Courage single, which has mixed reviews, and would require mods to make work. I checked for where other people had replace an engine on your model without any luck. Even checked for Briggs repowers to no avail. So as of now there isn't a replacement engine for your mower.
" So as of now there isn't a replacement engine for your mower"
Yikes! I hope there is something close that fits. Any suggestions as to engines that would be close is appreciated.
/ Blown engine; rebuild or replace with new #8
There are engines in the kohler and the briggs lines that would fit your mower, but will require modifying the wiring and the exhaust.
/ Blown engine; rebuild or replace with new #9
I would at least take it apart and see what the damage is. I've replaced broken connecting rods for small $$ and gotten more years out of an engine. Sometimes they make a mess inside though.
/ Blown engine; rebuild or replace with new #10
contact Equipatron.com
i replaced the engine on my Husquvarna thru them. includes free shipping. I paid $510.00 for complete unit. it came with new carb,fuel pump,etc. took less than 1 hour to swap unit out.
I was getting bids of $400-500 for a rebuilt unit.
give them a call. they were very helpful to me
Thanks for the responses;
grsthegreat; I will give Equipatron a call and see if I get a different story about there being no direct replacement available.
KubotainNH: I may have no choice but to tear into it but it will be my first time; not even sure where to start. Any good Youtubes you know for dis-assembly of a Kohler single cylinder?
/ Blown engine; rebuild or replace with new #13
I've never worked on a Kohler but would think it's similar to any other engine. Assuming vertical shaft here.... Remove the pulleys, pull the engine, clean up that end of the crankshaft so it's smooth and then remove the base. It will look kinda like this video inside but this is a 2 cylinder.
https://www.youtube.com/watch?v=rbsrOdJ7BkM
/ Blown engine; rebuild or replace with new #14
Kohler has all their service manuals available online free of charge, all you have to do is download them.
/ Blown engine; rebuild or replace with new #15
Wow; great input. Thx.
RandyT; great tip on downloading the manuals. That will help if I end up rebuilding.
Brad Blazer; Thanks so much for the suggestions on alternative engines that might fit.
For those interested here a a couple of photos of the engine. IMG_8232.JPGIMG_8233.JPGIMG_8234.JPGIMG_8236.JPG
/ Blown engine; rebuild or replace with new #17
TractorData.com John Deere LX255 tractor information
The machine is worth saving as it's equipped with a semi robust K62 instead of the flimsy K46 transmission. The nearest Deere replacement would be the X310 with the K58 or higher. Below they have the k46 transaxle.
1252218 15-16HP Command Shortblock, Vertical 1" x 3/532" Shaft Kohler Shortblock
Manufacturer:
Kohler
Price:$755.00
SV540-0220 18hp Courage Vertical 1" x 3 5/32" Shaft, OHV, ES, Oil Filter, 15 Amp Alternator Kohler Engine
Manufacturer:
Kohler
Price:$840.00
In Stock: 2
SV540-0222
SV540-0222 18hp Courage Vertical 1" x 3 5/32" Shaft, OHV, ES, Oil Filter, 15 Amp Alternator, Fuel Pump Kohler Engine
Manufacturer:
Kohler
Price:$599.00
In Stock: 33
SV590-3210
SV590-3210 19hp Courage Vertical 1" x 3 5/32" Shaft, OHV, ES, Oil Filter, Fuel Pump, 15 Amp Alternator, Kohler Engine
Manufacturer:
Kohler
Price:$675.00
In Stock: 93
SV590-3229
SV590-3229 19hp Courage, Vertical 1" x 3 5/32" Shaft, OHV, Fuel Pump, Electric Start, 15 Amp, Oil Filter, Kohler Engine
Manufacturer:
Kohler
Price:$615.00
In Stock: 130
SV601-3207
SV601-3207 20hp Courage Vertical 1" x 3 5/32" Shaft, Oil Filter, OHV, Electric Start, 15 Amp Alt, Fuel Pump Kohler Engine
Manufacturer:
Kohler
Price:$729.00
In Stock: 95
SV620-3210
SV620-3210 22hp Courage Vertical 1" x 3 5/32" Shaft, Electric Start, 15 Amp, Oil Filter, OHV, CIS,ツ Kohler Engine
Manufacturer:
Kohler
Price:$675.00
In Stock: 94
SV620-3222
SV620-3222 22hp Courage Vertical 1" x 3 5/32" Shaft, Electric Start, 15 Amp, Oil Filter, OHV, CIS,ツ Kohler Engine
Manufacturer:
Kohler
Price:$650.00
In Stock: 62
LEARN MORE
Compare
BuickandDeere; Thanks for the extensive list of options! Also good to know that the LX255 is worth investing the time and $$$ in. What engine supplier did you pull the data and prices from? Of the choice you mention do you see one as requiring the least modification or are all going to be pretty much the same?
If all things are pretty much equal would you go to the larger HP or does that just lead to other problems.
Thanks
/ Blown engine; rebuild or replace with new #19
just for haha's since you'll be taking the old engine out to put in a new one anyway, take it off and pull the 'pan' to see what's going on in there. Could be a simple rod cap bolt let go and might be a simple/cheap fix.
Since it's coming off anyway you've got nothing to lose but an hour of time to look at it before you order a new engine.
oldpilgram; Thanks; to look inside would you go from the top down or bottom up. The engine is off the tractor so can approach it whichever way is simpler...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2018 KUBOTA  RTV-X1140 (A63569)
2018 KUBOTA...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
CASE IH RB464 ROUND HAY BALER (A63290)
CASE IH RB464...
1997 JCB  436B WHEEL LOADER (A63569)
1997 JCB 436B...
