lifting bales
   / lifting bales #1
coranchin
san luis co
none
Starting a sheep farm have just 10 head right now, but looking to grow much larger. So with increased numbers im planning on going to big bales, what is a good size tractor to use. Nothing to big (I guess smallest possible ) or how do you know if the tractor is big enough
   / lifting bales #2
The pdf chart below shows round bales from 450lbs to 1700lbs, depending on size.
This site says 500 to 3000lbs.
G1955 Large Round Bales: Management | University of Missouri Extension
I would like 20% or more lift capacity than bale weight, just for safety under less than ideal conditions, such as hitting a pothole while carrying a bale.
A bale mover will let you get by with a smaller tractor, but you can't stack them.
Examples:
THE Slide Lift Bale Mover
Lovett & Tharpe Catalog - DURABILT INDUSTRIES | BALE MOVERS |
Bruce
  • SF1209.pdf
   / lifting bales #3
Sheep farmers over here stay away from big bales. They make a living at it! They even pay premium for small sq. Sheep are finicky.
   / lifting bales #4
What size of big bales are you talking?
Most CUT will handle a 4x4 hay bale.
you need a much bigger tractor for a 5x6 bale....
   / lifting bales
4x4 , and 1200-1400 rounds.
And wondering why do they stay away from big bales my nieghor sells big and small cut from same field
But I'm looking mostly Craigslist and similar sites for used tractors so is there a good place to look up lift capacity. And I'm looking in the 3k-5k price range
   / lifting bales #6
Huh, I've never fed a small square bale to my sheep ever. was big bales from 89 to 2011, been corn silage and haylage since, chopped and put in pit silo. think about less labour and you'll be able to feed more animals. Now about a tractor, I always liked going with older iron and get bigger for money. 50 to 60 hp tractors with loaders will last many yrs yet and will handle mowers, balers etc. just good all round size for smaller farms.
   / lifting bales
So a 50-60 hp will work. Sounds good
Looking to do brush hog, tiller, and disc work and the occasional big bale moving
Nothing to crazy no crops really just land prep for grazing
   / lifting bales #8
The hp/size of the tractor are one part of the equation. A robust FEL being another part AND the terrain is the third. Matching the three to the job at hand is the solution.
I have no problem using my 41hp tractor with a 300CX FEL over my relatively flat property. I have assisted a neighbour during haying season, gathering round bales over varying terrain & inclines, again, with no problems.
   / lifting bales #9
Depends on how old of tractor you get but if you are talking the $3-5k range you are talking 60s or 70s and some of those did not have the front axles strong enough to be handling 700-800 lbs while driving. For instance JD 3020 and 4020s broke a lot of front axles due to loaders. That pipe with holes in it wasn't very good for carrying a load on it and hitting a hole.
   / lifting bales #10
I guess We just had good luck, we handled 20,000 5x5 silage bales with a 4020, never had a bit of trouble, bought a 6403 mid 2000's and we cant keep that thing working (electronics), the 4020 still fills in when the new one is down. I would think about anything over 50 hp would handle smaller dry rounds, I currently do 4x4 dry with a JD 790, or my Massey 135.
LOT OF FLAT IRON (A58374)
LOT OF FLAT IRON...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2019 Ford F250 (A55973)
2019 Ford F250...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
