TRIVA FUN
/ TRIVA FUN #621
I have seen a C-130 flying Below me as I drove down a steep grade on an interstate highway. One wing tip was about twenty feet from the tree tops as he made a tight turn like a fighter jet should be able to do but a cargo plane should not attempt. A great plane and the guys that fly them have great skill and big brass cahonies !
/ TRIVA FUN #622
The video keep crashing. Finally got it to work & you are correct.
New Question!!
I though that mostly Ford & Mercury were the ones that made "Woodies". But doing a little research almost every major US car maker made 1 or more. At 1 time we had a Buick Woodie. Even Nash made a Woodie, Maybe in more ways than 1.
Who were the one or ones that didn't make a Woodie???
I'll take a WAG and say "Kaiser/Frazier".
/ TRIVA FUN #623
The video keep crashing. Finally got it to work & you are correct. New Question!! I though that mostly Ford & Mercury were the ones that made "Woodies". But doing a little research almost every major US car maker made 1 or more. At 1 time we had a Buick Woodie. Even Nash made a Woodie, Maybe in more ways than 1. Who were the one or ones that didn't make a Woodie???
Concerning the "more ways the 1", you had early vehicles with wood over wooden frames, then a combination steel frame / real wood approach and lastly - the "country squire wagon" method of faux wood grain vinyl. Many manufacturers had models using at least two of these methods.
/ TRIVA FUN #624
Remember this old joke?
Two rednecks just bought a new country squire wagon and when asked by their neighbour how they liked it said "Just fine, but it looked better when it was in the crate."
/ TRIVA FUN #625
Hadn't heard that one...It's a keeper. Some of my redneck friends will be getting this soon!
/ TRIVA FUN
Should we let this thread die???/
Henry Ford made a car out of ????? when there was a steel shortage.
It was so tough that even a sledge hammer would not dent it.
/ TRIVA FUN #627
Well I know the answer, but I "cheated"
I had read about it before, but I had forgotten it.
/ TRIVA FUN #629
In the movie "Up in Smoke", the protagonists drove a van the body of which was constructed of what substance?
/ TRIVA FUN
The 2 autos not what we would call a Woodie in the traditionally sense were Lincoln & Caddy.
Fords non steel body was made from something that at 2 different times was required for farmers to grow. It is now according to federal law illegal to grow.
/ TRIVA FUN
T astronauts left several flags on the moon. 1 The first 1 blew over when they left. Things were changed and the rest remained standing.
What Color Are they?????
/ TRIVA FUN #634
Apparently after doing some research, Hemp was only one small percentage of the compounds that went into making the plastic body panels on Henry Fords concept care.. Soybeans were a larger percentage that made up the plastic. But there is controversy on this.
/ TRIVA FUN
Compress ability
The P38 Lighting was 1 of the fastest fighters of WW2 & in a dive suffered from compress ability.
What is compressibility????
/ TRIVA FUN #636
Compress ability
Compressibility was a phenomenon of turbulent air flow over the control surfaces of the airplane whereby the pilot would lose control, with sometimes fatal results. Sometimes control would be restored as the plane got closer to the ground, but not always. As I recall, they eventually solved the problem by installing a special baffle of some kind that broke up the turbulent flow. The P-38 was a thoroughbred that suffered from teething problems, but by the end of the war, it was pretty much perfected and a very formidable fighter...not to mention it's beauty.
/ TRIVA FUN #637
The Vaught F4U Corsair was WWII fighter that actually continued production after the war. It was manufactured by Vaught, Goodyear and Brewster. In action in the Pacific, it was flown from land bases, and later from carriers. It was known to the Japanese as "Whistling Death" because of the sound of the air through the oil coolers. It had a phenomenal kill ratio of 11 to 1 against the Japanese. There was one other American fighter aircraft that had a kill ratio significantly higher...19 to 1...what was it and who was the manufacturer?
P.S. I would highly recommend the book "Whistling Death", the story of the development of the Corsair, written by the test pilot, Boone T. Guyton. There is also another book that I highly recommend to you WWII buffs, entitled "Reach for the Sky", the story of a legless British pilot who flew Spitfires against the Germans using artificial legs. His name was Douglas Bader, and he lost his legs in a crash while showing off for some girls. He was a good pilot, and the British, being desperate for pilots, put him back in a fighter plane where he shot down something like 20 German aircraft.
/ TRIVA FUN
American Navy was afraid to land a Corsair on a Carrier.
Who figured it out & what was the trick ????
/ TRIVA FUN
While a crew member on a sea plane, a few times we carried an atomic weapon. I though it was an A bomb.
But wasn't. What was it?????
/ TRIVA FUN #640
Most likely an H bomb which uses a A bomb as a fuse to get the hydrogen to fuse at the same temps and pressures as the center of the sun.
2022 Horizon Trailer (A55973)
2022 Horizon...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
(2) 460/85R42 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R42...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
