Got the backhoe stuck today
/ Got the backhoe stuck today #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Doing some tiling today. Got buried. From the pictures you can see why we are running a tile.
She couldnt walk herself out of this one. Using the hoe and loader to lift, we filled the ruts with some firewood and used the kubota to pull.
IMG_20150321_134828_695.jpgIMG_20150321_134826_314.jpgIMG_20150321_134840_626.jpgIMG_20150321_134852_087.jpg
/ Got the backhoe stuck today #2
That was stuck pretty good. Are you in an old pond bed or just a low area?
Just a low wet area. It is about 50 yards from a leaky pond though. You can see the pond bank in the background among all the brush
/ Got the backhoe stuck today #4
Was there just not enough "bottom" for the hoe to push down on and lift the tractor?
Yes the hoe would lift the tractor, but as buried as the front was, it still wouldnt push through it.
If it was my hoe I would have used the swing and tried to find firmer footing for the rear axle. But dads 4500 has a swing chain. And he has broke it once doing that a time before.
/ Got the backhoe stuck today #6
That's some impressive mud!
/ Got the backhoe stuck today #7
That is a fine job of getting stuck.
Well done, my friend!
So you got it out, you say?
Must have been close to some solid ground, cause that that machine is in there.
/ Got the backhoe stuck today #8
You need different tires. Slicks are not mud approved!:D
/ Got the backhoe stuck today #9
What he said, Be sure to update your resume, employers are looking for people with that kind of thoroughness ;)
/ Got the backhoe stuck today #10
Nicely done!
/ Got the backhoe stuck today #11
I LIKE IT !!!! Nothing like getting her stuck good. Adds excitement to the day!!! I've not been stuck in a while ... thinking about it though!!!
/ Got the backhoe stuck today #12
could have left it until the ground froze up. It'll probably freeze again in about 8 or 9 months.
/ Got the backhoe stuck today #13
Another atta boy! If you don't get stuck occasionally you're not trying hard enough.
/ Got the backhoe stuck today #14
Great job! I was so happy it was a full size machine and not a b series wanna be stuck in a mud puddle!
/ Got the backhoe stuck today #15
That's what we call belly hung. :(
/ Got the backhoe stuck today #19
I bet dinner was late. Must have taken the wife quite some time to get that tractor cleaned up.
Nice old Iron. When men were still men and tractors were tractors
/ Got the backhoe stuck today #20
I have been practicing , but I just cant get stuck that good yet .
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
