locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #191
I have two fittings I still have to do manually using a 90 degree adapter from the pistol grip gun due to the large size of the LNL not fitting into the required area.
Same here. I have ONE fitting on a mower deck that requires a 90-degree adapter for which I use one of my other grease guns. But for everything else it's "Whoo Hoo... grease time is fun time!" :)
   / locknlube cupler for a grease gun #192
see my post above ^^
   / locknlube cupler for a grease gun #193
Here is the 90 degree adaptor I made to easily clip on to the LNL so I could get those two fittings under the floorboards of the Kioti
View attachment 415288View attachment 415289
Thanks JK. I have a different type of 90 adapter that just does not work all that well. Just put this one on my Amazon Wish List for the next order.
   / locknlube cupler for a grease gun #194
Mine seems to work pretty good, but I have only used it twice. You know those 2 stupid Zerks that should be 90 degree zerks under the floorboard of the DK. But they are British Straight Pipe thread I think, so I made the adapter instead of trying to find replacement zerks.
   / locknlube cupler for a grease gun #195
James;
Replacement grease zerks are easy and very low cost way to solve a frustrating issue.
Steel Lubrication/Grease Fittings
Sent from my iPad using TractorByNet
   / locknlube cupler for a grease gun #196
Replacement grease zerks are easy and very low cost to solve a frustrating issue.
   / locknlube cupler for a grease gun #200
Without a doubt, some of those would work.
I have one of those Lincoln 90 degree adapter fittings you noted and my results were not great. Wonder why Kioti would use BSP fittings?
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
Walking Floor Trailer (A50322)
Walking Floor...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2007 Great Dane Flat Deck Trailer (A50514)
2007 Great Dane...
