OP
SandburRanch
- Joined
- Oct 12, 2010
- Messages
- 1,543
- Tractor
- NHtd75
What kind of car is it?
2013 Equinox
+1 This is how all regular automatic transmissions operated. TH350, TH400, TF727, C4, C6, and virtually every other common automatic. The big change was the manual shifted electronically controlled automatics introduced in the past 10 years. Now you select D or M, and then select + or - to manually select a gear if you want to control anything.
2013 Equinox
I've seen lots of funny sights at boat launching ramps, at least a couple of which resulted in the towing vehicle going into the water. But my first showroom new car was a 1962 Austin Healey Sprite (first year that wasn't a bug eyed model) and I had a local mechanic make and weld onto the frame a trailer hitch. I used to pull my Dad's 16' Texas Maid Fiesta boat with a 35 hp Evinrude outboard. I never had a problem at all, but when I got on a launching ramp to launch or retrieve the boat, I usually drew a crowd waiting to see if I could do it.
You didn't purchase a FWD NOX and then wonder why it spins? The wife's AWD Terrain with Michelin Ice X 2 tires will push snow with the front end while driving up hill.
Lots of vehicles, my pickup included, have Traction Control Systems that reduce power to the wheels if a slip is detected. It can be disabled if necessary. I wonder if this system works as well or better than starting in second gear?
If I had the money for a new car, I'd be getting a manual, so I haven't played with the new automatics - there may be one out there that does what you want.
Not at all. The post was about how auto manufacturers are screwing the usefulness of transmissions up. I'm real happy your wife's car can push snow up hill.
Read the title then twist it however you like. We knew what would happen when ask and I told what car we bought. I suppose that's just the nature of humans on forums and if I recall it has been established by the Admin. brand bashing isn't to be tolerated.Reading your first entry is about your vehicle spinning .
If your problems with your vehicle that you posted on this site is too personal ? Then just what exactly do you have in mind? Your 2WD vehicle without winter tires will tend to spin. Tis the laws of physics they are not personal.
You guys have no idea how good a well designed traction control system can be. The system on my Ford F150 rocks.
