Steel for DIY Fire Pit - Advice Needed
   / Steel for DIY Fire Pit - Advice Needed #11
we actually use the tire rim. works great. put some rocks around it and it kinda has rusted up and blends in.
   / Steel for DIY Fire Pit - Advice Needed #12
I like the rim idea, especially from a recycle standpoint. I still want to fabricate something a little bigger. I guess around here it is hard to find big rims!
   / Steel for DIY Fire Pit - Advice Needed #13
Way, way back in my wood burning days. I built several wood stoves, and fire place inserts for friends, and family. Can't say I ever built a fire pit tho. I always used 1/4-inch thick material, but also used fire brick.
VERY cool
   / Steel for DIY Fire Pit - Advice Needed #15
Just get an old tractor rim. Modify as you see fit. I've had intentions for this one, but it works fine as is.
Agreed. The best ones I ever saw were no more than big and wide tractor rim. Auctions and tractor boneyards are where to look if interested.
   / Steel for DIY Fire Pit - Advice Needed #16
I took an old burned up floor fan from the barn and cut the guts out of it. I have used it a year and it may last another year. I save the blades out of it also. I'm going to mount them on top of my mule to make a helicopter out of it.
   / Steel for DIY Fire Pit - Advice Needed #19
where do you get them???
   / Steel for DIY Fire Pit - Advice Needed #20
Several times an anti-warp rim has been mentioned. How about making that rim 3 to 4 inches wide, and level, for a food warming place.
Bruce
6 Inch Stargrip (A57454)
6 Inch Stargrip...
2020 Deere 50G (A53317)
2020 Deere 50G...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
1997 Peterbilt 378 Tri-Axle Heavy Haul Truck, VIN # 1XPFD69X4VN428289 (A57453)
1997 Peterbilt 378...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
