Steel for DIY Fire Pit - Advice Needed
   / Steel for DIY Fire Pit - Advice Needed #11
we actually use the tire rim. works great. put some rocks around it and it kinda has rusted up and blends in.
   / Steel for DIY Fire Pit - Advice Needed #12
I like the rim idea, especially from a recycle standpoint. I still want to fabricate something a little bigger. I guess around here it is hard to find big rims!
   / Steel for DIY Fire Pit - Advice Needed #13
Way, way back in my wood burning days. I built several wood stoves, and fire place inserts for friends, and family. Can't say I ever built a fire pit tho. I always used 1/4-inch thick material, but also used fire brick.
VERY cool
   / Steel for DIY Fire Pit - Advice Needed #15
Just get an old tractor rim. Modify as you see fit. I've had intentions for this one, but it works fine as is.
Agreed. The best ones I ever saw were no more than big and wide tractor rim. Auctions and tractor boneyards are where to look if interested.
   / Steel for DIY Fire Pit - Advice Needed #16
I took an old burned up floor fan from the barn and cut the guts out of it. I have used it a year and it may last another year. I save the blades out of it also. I'm going to mount them on top of my mule to make a helicopter out of it.
   / Steel for DIY Fire Pit - Advice Needed #19
where do you get them???
   / Steel for DIY Fire Pit - Advice Needed #20
Several times an anti-warp rim has been mentioned. How about making that rim 3 to 4 inches wide, and level, for a food warming place.
Bruce
CAT 259D Track Loader (A57453)
CAT 259D Track...
John Deere Metal Sign (A57454)
John Deere Metal...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2018 Ram 3500 4x4 Service/Utility Truck, VIN # 3C7WRTCL0JG387527 (A57453)
2018 Ram 3500 4x4...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
