Ford releases fuel numbers for the new F-150
Status
Not open for further replies.
   / Ford releases fuel numbers for the new F-150 #71
How can it win the comparison test if it cant (legally) haul their test load? Their 1000# test load puts the Ram 40# overweight (payload is 960#) before the driver even gets in the truck.
Aaron Z
I just love checking on on these threads for stuff like this. I didn't go back all the way but I expect some more from the Ford folks like Diamondpilot are in this thread.
   / Ford releases fuel numbers for the new F-150 #72
   / Ford releases fuel numbers for the new F-150 #73
   / Ford releases fuel numbers for the new F-150 #75
Looks like they may not have gotten one with the "Trailer Tow Package" and as such it was only rated to tow 5000#.
Aaron Z
I know! Isn't that the craziest thing.. I'm surprised it didn't collapse under the load! !!
   / Ford releases fuel numbers for the new F-150 #76
At idle yes, at cruise it would absolutely be pulling vacuum.
I'm not quite sure I understand how you came to this conclusion, for a turbocharged engine. I can't speak for a gasser, but my Duramax is running about 12 psi at cruise. It runs about 5 or so at idle.
   / Ford releases fuel numbers for the new F-150 #77
I thought the same thing. Not sure how you could have a vacuum downstream of the turbo.
   / Ford releases fuel numbers for the new F-150 #78
   / Ford releases fuel numbers for the new F-150 #79
Because a turbo is not producing boost until it's spun up. If a turbo was producing boost all the time there would be no efficiencies to be found.
   / Ford releases fuel numbers for the new F-150 #80
The Motor Trend article. Mostly the acceleration numbers in the chart. The only one that gets the 7000 lb trailer 70MPH score.
Comparison: 2015 Ford F-150 vs. Ram 1500 vs. Chevrolet Silverado All Pages
The article also says that in the end the AL materials gave them pause because of the unknowns. Me, I give Ford credit for pushing the envelope. They should have won.
I must be missing that chart on my tablet, because from the text it says they are all able to accelerate from 60 to 70 mph, on a steady 6% grade.
Status
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
TAKEUCHI TB235-2 EXCAVATOR (A51242)
TAKEUCHI TB235-2...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
