DIY Bike Chain .... Bolt Cutters vs. Chain
/ DIY Bike Chain .... Bolt Cutters vs. Chain #1
Teleological
Gainesville
None
What grade and thickness of chain would you recommend for making a bike chain that is resistant to bolt cutters? I'm just going to go all out and say assume that the thief has a pair of 48-inch hardened bolt cutters.
So what grade and thickness chain would you trust to defeat a pair of 48-inch bolt cutters?
I checked my local hardware stores and I don't think they stock any grade 70 chain ... only grade 40 at the most, and all are less than half an inch thick. Will those do the trick?
/ DIY Bike Chain .... Bolt Cutters vs. Chain #2
Bolt cutters may have some difficulty with certain chains, but no chain or cable will last a minute when attacked with a simple battery-powered grinder. I'd think in terms of a chain or cable plus a loud alarm?
/ DIY Bike Chain .... Bolt Cutters vs. Chain #3
Welcome to TBN. I agree with chim. You might find chain that is somewhat resistant to bolt cutters but then some other area will become the "weakest link". I would also suggest some kind of alarm or finding a more secure location for the bike. Besides - I doubt a truly HD chain would function well on the bike.
/ DIY Bike Chain .... Bolt Cutters vs. Chain #4
My solution in college was buying a $10 ratty looking bike that no one would think of stealing and securing it with a $40 lock and chain.
/ DIY Bike Chain .... Bolt Cutters vs. Chain #5
Hoist chain is much tougher to cut than plain hardware store chain.
/ DIY Bike Chain .... Bolt Cutters vs. Chain #6
take the chain, seat and front wheel with you when you park it ;-)
/ DIY Bike Chain .... Bolt Cutters vs. Chain #8
Would the wasp nest thing work on a bike?
/ DIY Bike Chain .... Bolt Cutters vs. Chain #9
Carzapper- Now can you see somebody using that at the local Walmart? And then a small child touching the car? Instant lawsuit at the least. Jail time most likely.
/ DIY Bike Chain .... Bolt Cutters vs. Chain #10
aircraft cable and a hardened lock would be better against bolt cutters ... but as stated , a zip rotary tool with blade will make short work of either ....
"all bikes weigh 50 pounds .... a 45 pound bike needs a 5 pound chain and lock , a 5 pound bike needs a 45 pound chain and lock "
iDrive TDS-2010H...
2019 F-550 Bucket Truck (A61307)
2019 F-550 Bucket...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2014 Vermeer Vac-Tron MC533SDT Heavy Duty Vacuum Trailer (A60352)
2014 Vermeer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
