2001 TC40D Rear Remotes
   / 2001 TC40D Rear Remotes #1
Summdude
Olean,ny
New Holland TC40D
I have been considering installing rear remotes on my TC40D until I called the dealer to get a price... They wanted $975 for the kit! Anyone know where to find this kit maybe a little cheaper?
   / 2001 TC40D Rear Remotes #2
NH parts are not cheap. Messick's shows the kit for #1 is $985 and #2 is $935 so your dealer is not ripping you off. Don't forget the shipping cost. See if your dealer will throw that in.
   / 2001 TC40D Rear Remotes #3
I got lucky last year and found a first remote for my 2004 Case DX45 at a dealer for $650. The dealer had it in stock and since it did not fit any current models he was willing to discount it quite a bit. The Case and NH are the same (other than color) so you may want to call around and check.
Ok! Thanks for the info!
   / 2001 TC40D Rear Remotes #5
I got my rear remotes a few years ago when I picked up my used Bush Hog BH from a dealer down in SC. Since I need the remotes and I bought the BH off him he gave me the remotes for $200. Probably old stock and just wanted to get ride of them.
maybe call around and see, but now that the tractor is 12-14yo it might be a little tough finding them in stock at a dealer.
Good Luck
gary
I have spent a little time searching and calling around with no luck. This may sound ridicules but what if I removed the FEL and made up some lines that could reach from where the bucket hooks up. Of course it would be a temporary fix but it could work, right?
   / 2001 TC40D Rear Remotes #7
Why don't you want to buy the kit from Messicks instead of jerry rigging something? $985 is a lot of money, but sometimes that's the cost of doing something 'right' and being able to use your FEL and the rear remote at the same time.
I really don't want to "jerry rig" something but the bottom line is, I just don't have the $ right now. Maybe the best thing is to continue to research and hope I come across something. I am in western NY and we aren't haying now... I could however use a snowblower. :)
   / 2001 TC40D Rear Remotes #9
It's not a brand new tractor and the part for a tc 40 might be the same on some other model NH, Case, maybe LS. I'd get that part # and scour the online boneyards looking for one from a junkyard. Decades ago I got lucky and got a junkyard remote kit for maybe 75% off.
   / 2001 TC40D Rear Remotes #10
Woods Gannon had a top n tilt kit for TC40's. Check with Messicks and get the parts breakdown (TL429 Kit) as it uses an adaptor block that goes on the 3 point quadrant valve. They did have a single or double spool valve top and/or tilt kit that you could diagram. You can buy a valve through Tisco or other aftermarket that will mount on fender. Quick couplers are Pioneer 1/4" or whatever you desire. Sorry I don't have numbers, but I can't get Messicks Woods parts section to work and I can't find in Woods website.
2018 International DuraStar 4300 TMA Attenuator Truck (A55973)
2018 International...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A55973)
2010 International...
36" Excavators Bucket Attachment (A56857)
36" Excavators...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2026 tilt trailer (A56859)
2026 tilt trailer...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
